diff fluids
Old Dec 30, 2008 | 12:08 AM
irelandshemi's Avatar
irelandshemi
Default diff fluids
want to change the fluids on my 03 ram 1500 hemi just wanted to get a quick how much fluid to put in what kind 70-? and do i have to add the posi fluid how much of that whatnot any info would help i know how as far as bolts ect just dont know how much and what kinds of fluid
Old Dec 30, 2008 | 12:22 AM
dirtydog's Avatar
dirtydog
Moderate User
owners manual!
Posi fluid is only needed if you have limited slip. If you have an open carrier (one wheel peel) no additive is needed.
Old Dec 30, 2008 | 12:26 AM
irelandshemi
last year my truck got broken into they stole my 2 15's indash and decided to burn my owners manuel insurance and registration, so im lost as far as looking into that, and yeah theres no anti slip anything or lsd in the glovebox so i dont think i need that but just wanted to make sure
Old Dec 30, 2008 | 12:31 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Originally Posted by dirtydog
owners manual!
Does dodge still want us guys with the open rear to do the 15k intervals? Seems like a waste to me..
Old Dec 30, 2008 | 12:45 AM
dirtydog's Avatar
dirtydog
Moderate User
It's 30kmi intervals unless you do heavy hauling.
YES. The bearings and ring&pinion still need fresh lube. That's the whole reason behind the intervals.
Changing fluids in a differential regardless of open or limited slip is the same in any case. If you do more hauling, than you need to change the fluid sooner.
Old Dec 30, 2008 | 12:52 AM
SeVeReDiStOrTiOn
Old Dec 30, 2008 | 12:56 AM
dirtydog's Avatar
dirtydog
Moderate User
change of heart....lol
Old Dec 30, 2008 | 01:02 AM
SeVeReDiStOrTiOn
I remember seeing something about 15k for the rear and thinking how ridiculous it was...i'm going to have to double check that before I reach 15k. I hope it's 30k that's what i've always done them at...15 is just a little excessive.
Old Dec 30, 2008 | 01:05 AM
irelandshemi
any one know fluid amounts and what weight
Old Dec 30, 2008 | 01:07 AM
dirtydog's Avatar
dirtydog
Moderate User
For the first change i would def do it at 15kmi or sooner regardless. I have 2800 miles as of right now and probably will have about 5kmi by springtime and my diff fluids will get flushed out for some new juice. The first change is the most important as the bearings run their initial wear and as do the ring & pinion. I have Synthetic fluids in my diffs and I believe you do as well. I think the 15kmi is just a level check and not a fluid change like the 30kmi, however, I would really reccomend doing atleast the rear diff in any 4x4 application at 15kmi and then both again at 30kmi.
My first oil change was just before 1kmi. I went fully synthetic. My next oil change will be at 5kmi and then every 5kmi there after.
