Old Aug 5, 2015, 07:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
Intermittent Wipers Not Working!!
Old Dec 10, 2013 | 11:45 AM
  #21
bulldodgemoe's Avatar
bulldodgemoe
start here instead of another thread.
also have the low and high work only. i took the motor apart and looked good "i guess"
i did a vdc check and found when i have the low and high on i had 12vdc at the plug, but when in intermittent mode i had non, no vdc. could it be the pulse intermittent control as rangemare found or maybe the relays?
Old Dec 29, 2013 | 08:17 PM
  #22
bulldodgemoe
Thought I would tell you what it was. It was the buzzer the annoying buzzer that let's you kbow the door is open. Key in ignition etc. I think it maybe called the central timing thingy.
Old Jun 18, 2014 | 11:53 AM
  #23
kgibbs420bossman's Avatar
kgibbs420bossman
Default wipers
Originally Posted by Tonyo88
I have the exact same problem, changed out the switch and it didn't fix it. I checked with Dodge to see how much a new wiper motor costs, they told me around $250.00. So I think I'll just deal with it until someone finds a cheap solution.
Check the thing under the dash that makes the chime when you turn the key on or when u get low on fuel thats what made my intermitent wipers quit working i changed that and they work beuatiful
Old Jul 26, 2014 | 11:25 PM
  #24
slovo's Avatar
slovo
This thread was discussing the issue on the ram, the dakota issue is a different system.
3rd gen rams have a Front Control Module (FCM) that controls the intermittent control of the wipers, among other things. its located under the fuse box in the engine compartment. Reading other threads its almost never the issue.
I have the same voltages as you do, there are 4 wires on the 3rd gen rams. Brown/Grey stripe is the park switch, Brown/White stripe is the low relay, Brown/Orange stripe is high relay, Black/White stripe is ground.
A click from the relays should be heard when turning wiper switch to intermittent from the on/off #55 relay. Click from the low, and another one from high, both from the #60 relay. But then again just because they click does not mean everything is proper.
Google the testing procedure for the reley in questing and you will see what I mean. Mine are 8 ohms out of tolerance. Suppose to be 75ohms +/- 8ohms. I got 89ohms. Might be part of the problem.
I Checked resistance of ground to battery terminal, 7 ohms, thats ok.
When wipers were set to high i got voltage on Brown/Orange wire.
When wipers were set to low i got voltage on Brown/White wire.
Intermittent I got nothing on either of those.
I am going to follow this diy fix and see what happens.
https://dodgeforum.com/forum/3rd-gen...r-diy-fix.html
Across multiple threads, its sounding like the issue is in the motor quite often. LOL my parts guy was right to offer me up a motor when I was thinking relays and wanting to take apart my switch.
Old Feb 19, 2017 | 05:25 PM
  #25
Edward Closson's Avatar
Edward Closson
Default Try this first and save yourself some heartache
Thanks for all the info, after replacing the switch the wiper worked for a second, after replacing the wiper motor it worked initially then reverted back to its old ways of not working, and finally when I replaced both relays in the fuse box and let then engine charge the box a minute the wipers finally, after years of not working correctly, had the intermittent feature. In short, if your motor works, the switch works, start with the relays. From AutoZone it cost about $25 for both relays. Then to the wiper motor if the relays don't work at about $50. Then try the switch which is the last ditch effort.
To the members of this forum thank you for your assist, a happy ram truck owner.
Old Feb 25, 2017 | 12:57 AM
  #26
michael beez's Avatar
michael beez
Default wiper delay fix
HA!
just went through this issue about a month ago.
After reading through some of these forums i decided to tackle. someone suggested to take the motor apart and basicly clean the darn thing. Correct me if I'm wrong, but, the issue is most likely not going to be the switch or relays or fuses . open the wiper motor. If you look at the contacts inside you will notice that they are probably worn down. Get yourself a pair of needle-nose pliers Bend those contacts very carefully with a slight pressure, you probably don't want to break them. Grease the contacts and other surface area, installation is opposite of removal... VOILA !!!!!!
Old Dec 31, 2019 | 11:54 AM
  #27
Frankie G's Avatar
Frankie G
I have a intermittent wiper module under the dash and I believe it's only for the intermittent wipers and not for hi and low which my truck has anyone else run across this ??
Old Jan 1, 2020 | 08:32 AM
  #28
What are you driving?
Old Feb 16, 2020 | 07:04 PM
  #29
Bill Lathum's Avatar
Bill Lathum
Default I'm about ready to give up. 2005 Dodge ram 1500
Hello all, been reading everyone's posts and this issue is kicking my butt. I put the wipers on slow intermittent and nothing... Turn them on low and then turn them off quickly and wipers stop in the middle of the windshield. Or, I put them on slow intermittent and the wipers just go like they are on low! Or... They will wipe on low intermittent about 4 or 5 times then stop... Heck I turned the corner the other day with my wiper switch OFF and they turned on for like two swipes!!! I have replaced the motor, switch on the steering column and one relay. I am out of stuff to replace and frankly sick of throwing money at it and it not working. Anybody help??? Please
Old Jan 3, 2025 | 04:09 PM
  #30
Dragiton's Avatar
Dragiton
Default Intermittent wipers not working???
Originally Posted by WildBill2500
My intermittent wipers sometimes work, sometimes don't, sometimes do a few swipes, sometime stay on constantly. The high & low wiper functions work fine.
I bought my '05 Ram 2500 last year and it would make 2-3 cycles at a time and I never thought anything of it. Now, they seldom work and it is a challenge while plowing...
I have already changed out the multifunction switch, but still have the same issue.
Any thoughts?
Hello, I found that if you check your fuse box, you will find a relay marked wiper park. Mine was bad replaced it and fixed it.
