Solid Axle Swap
Old Jan 12, 2009 | 11:17 PM
Redone4x4's Avatar
Redone4x4
4.56 in the rear would call for 4.57 in front, 3.55 in rear calls for a 3.56 in front, etc. That is what I found out when I was going to swap out on my old 97 ram. The front always pulls 1/100th more than the rear, it helps with stress on components, steering, etc...thats what I obtained when I was researching axle swaps.
Old Jan 12, 2009 | 11:26 PM
hemiguy0302's Avatar
hemiguy0302
Yes in theory this does make sense but I do not think any gear manufacturer makes a 4.57 or a 3.56. The goal is to try and match the gear ratios in the front and rear axles if not get them as close as possible. The only way two completely different gear sets would work is if two different sizes of tire were used to equal out the gearing differences.
Old Jan 12, 2009 | 11:30 PM
Redone4x4's Avatar
Redone4x4
you are correct hemiguy, from what I understood, when you order a 3.55 front, it is actually a 3.56, knowing that you have a 3.55 in the rear. The manufacturer doesnt include that bit of information to the general public i guess. This is what the major driveline shop in town described to me. basically, order the same exact ratio front and rear, put the front in the front, and the rear in the rear, and it should pull 1/100th more by the front axle.
Old Jan 13, 2009 | 12:01 AM
hemiguy0302
oh okay that makes sense then.
Old Jan 13, 2009 | 12:33 AM
cyclone429's Avatar
cyclone429
Once you get the gear ratios worked out, get a locker in the front, with all the time, money and effort you putting into this,, you don't want A 3 wd.
Old Jan 13, 2009 | 12:41 AM
Mattcmdr's Avatar
Mattcmdr
didnt mean ot ask a dumb question i have heard that it was fine and that it was bad but i was trying to get sum more feedback
Old Jan 13, 2009 | 12:45 AM
Redone4x4's Avatar
Redone4x4
yes they need to be the same. or else stuff breaks.
Old Jan 13, 2009 | 01:56 AM
Chris1530's Avatar
Chris1530
Well good luck with the swap.. Leaf springs would be easy, Coil over factory type setup, will be ALOT of work.. and means you wheels wont have the same bolt pattern, unless you have the fronts redrilled(if you can on a Dana 60)
Old Jan 13, 2009 | 02:29 AM
Hoss356's Avatar
Hoss356
Originally Posted by draco8494
i know a guy (this is a strictly mud slingin truck) it was a ford with a 9" out back and a dana 44 up front he had 3:56 gears in back and 3:73 gears up front and it ran fine
3.73 divided by 3.56 = 1.04% difference....
Click here
http://www.ringpinion.com/ContentFra...ferentials.inc
Old Jan 13, 2009 | 10:11 AM
oefootball_70's Avatar
oefootball_70
There is a guy on here that did a front axle swap. Look him up.
