Solid Axle Swap
Old Mar 17, 2009 | 06:38 PM
  #31
EKUSMC's Avatar
EKUSMC
Seems alot easier to just get a 2500, but if not whats a price tag for a axle swap?? The advantage for this is that you are still paying registration on your 1/2 ton truck apposed to doubling it with a 2500, here in Ca. a 2500 is around $500 a year, so in the long run the axle swap could pay for itself!! My 2 cents.
Old Feb 18, 2010 | 09:52 PM
  #32
mean_sob610's Avatar
mean_sob610
Default 1997 dodge ram 1500 front solid axle conversion
does anyone know where i can find info on sfa conversions for a 1997 ram 1500. mines is 2wd and im trying to convert it. i cant find anything. id appreciate the help. thank you.
Old Feb 18, 2010 | 09:59 PM
  #33
JoeHemi's Avatar
JoeHemi
I would recommend posting a new thread in the 2nd gen Section of the forums requesting this info. Good luck!
Old Feb 18, 2010 | 10:18 PM
  #34
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by cyclone429
Once you get the gear ratios worked out, get a locker in the front, with all the time, money and effort you putting into this,, you don't want A 3 wd.
Actually the setup is locker in the rear and LSD in the front. A locker in the front doesn't steer, and a locker in the rear still likes to point the front left and right depending on traction. Been there....
Old Feb 18, 2010 | 10:24 PM
  #35
98cherryram's Avatar
98cherryram
This thread is really old btw... who has that one image of brought back from the grave? lol.
But while we are here, why would someone do a SAS swap unless they had limitless money, when they could just buy an older 1/2 ton 94-01 for less than what the SAS would cost, keep their newer truck nice and comfortable and stock, then build up the 2nd gen dodge into a wheeler...? Those ones were beasts out wheeling anyways, I remember the crap I used to run my 98 through.
Old Feb 18, 2010 | 11:35 PM
  #36
95_318SLT's Avatar
95_318SLT
Originally Posted by Hoss356
3.73 divided by 3.56 = 1.04% difference....
Click here
http://www.ringpinion.com/ContentFra...ferentials.inc
Um, yeah... math doesn't work that way. The percent difference is:
|3.73-3.56|
___________
(3.73+3.56)/2
which comes out to be a 4.66% difference.
Old Feb 19, 2010 | 05:32 PM
  #37
OlDirtyJohn's Avatar
OlDirtyJohn
reg cost for a 2500 in CA is $302 a year
