factory wheel problem
Old Jan 18, 2009 | 03:17 AM
gmbymn948's Avatar
gmbymn948
Default factory wheel problem
Has anyone had problems with the 20" stock wheel/tire combo leaking significant amount of air out? I've had my tire checked for holes and reset on the rim twice in the past year, only to have it start leaking air out again. basically, losing 5lbs per day. Could the rim have a chip or crack in it? warrenty?
Old Jan 18, 2009 | 06:11 AM
lxman1's Avatar
lxman1
Site Moderator
I haven't. Have you put the whole assembly in a tank of water to look for bubbles?
Old Jan 18, 2009 | 08:18 AM
gmbymn948's Avatar
gmbymn948
yup, only around the bead were there bubbles
Old Jan 18, 2009 | 08:34 AM
bolang's Avatar
bolang
You will most likely have to buy a new rim.You can try taking it to dealer but they will claim you jump curbs and wheel out of round.Good luck
Old Jan 18, 2009 | 08:52 AM
dirtydog's Avatar
dirtydog
Moderate User
So no air leaking at the valve stem?
did you see if there was any corrosion at the rim where the tire bead sits against? Generally whena tire is mounted, a wire brush is used to smooth out the inner lip to remove any forein debris, excess rubber and any corrosion build-up.
If you have the factory tires still on and within the warranty, I would go to the dealership and tell them they need to fix it. Not ask them if there's anything they can do because they will tell you no. You need to TELL them. Anytime most people go to the dealer and ask a question for warranty related service, they usually get a "no, not covered" because the dealer won't make any money on warranty work. If you tell them they ned to fix it, they will think your are not going to be sent away easily and will perform the work if it's suppose to be covered.
If there's no significant curb rash on the wheel, they have to replace it or fix the problem. End of story. A tire can and will mold to a deformed rim even if you were "jumpin" the truck as Bolang stated which prob isn't true. If your rim was bent is ANY way, especially out-of-round it would be out of balance and shimmy at most speeds above 30mph.
Old Jan 18, 2009 | 09:00 AM
SeMiGoD's Avatar
SeMiGoD
I was gonna suggest swapping the valve stem and why not take the spare tire and mount it to that rim and see if anything changes. It will at least tell you if the rim or tire itself is bunk.
DirtyDog, nice to see ya back again. Did you get me a shirt?
Old Jan 18, 2009 | 09:17 AM
dirtydog's Avatar
dirtydog
Moderate User
Only got my nephews shirts this time...lol
They are-----Jamaica....No Problem (That's one of their sayings)
On the 06 you should have plain ole valve stems and not any TPMS devices, so that should be easy enough. The dealer should still cover a tire bead under warranty through the tire manufacturer.
Old Jan 18, 2009 | 09:31 AM
HammerZ71's Avatar
HammerZ71
'Dog, I thought I banned your a$$!!! Ahh sh*t, musta just been wishful thinking. Well, postwhore, there goes the friggin' neighborhood again...
Old Jan 18, 2009 | 09:42 AM
dirtydog's Avatar
dirtydog
Moderate User
Nah, I had a quota to hit ya know? i'll keep things freed up so you can feel a bit more important with your answers....lmao
No complaining MR. Cocoa Beach. I almost bought a house there 4 or 5 years ago. Lots of people are telling me good thing I didn't.???? Economy is over run they say down there. Anyways, let's keep this thread to topic discussion.....hehehehe
Old Jan 18, 2009 | 11:32 AM
putunxtc's Avatar
putunxtc
I would have the dealer fix your problem. It sounds fishy to me. I would also suggest using nitrogen in lieu of air once the problem is fixed. Nitrogen is a larger molecule than air which makes it harder for it to escape, unless it is a huge hole. Also, the benefit from nitrogen is there is not any water molecules like air. This will mean no expansion and contraction of the tire in different weather temperatures.
