flatten spark plugs
Old 01-18-2009, 07:52 PM
draco8494's Avatar
draco8494
draco8494 is offline
+2 to bringin it back to the stealership....just love being able to stick it to them when the vehicles under warranty
Old 01-18-2009, 08:29 PM
Redone4x4's Avatar
Redone4x4
Redone4x4 is offline
on my truck, the #4 and #6 plugs shattered, and the dealer had to rebuild the two cylinders, it put holes in the pistons. they claim that #6 cylinder predetonates and this has happened several times before. on mine, it threw a misfire CEL code. i posted on it a few weeks back. it was covered under warranty.
Old 01-20-2009, 03:31 PM
ce2flaco's Avatar
ce2flaco
ce2flaco is offline
It was #6 on mine as well. The plug electrodes were pushed flat after they were impacted by a piece of the piston that had literally broken off and bounced around in the cylinder. I also had the misfire CEL. They say the thin lip where the top ring sits tends to chip off.
I have a later model hemi in my 03 now (under warranty).
Word of caution: Avondale Dodge here in AZ told me that nothing was wrong with the truck and sent me on my way after saying that i had not gapped my plugs correctly. I then went straight to Lou Grubb Dodge (barely made it there on the trucks last legs) where they put a scope into the cylinder and found the problem in a matter of minutes.
There is a huge difference in dealers...be sure they don't jerk you around.
Old 01-20-2009, 07:16 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Originally Posted by brungsc
Yes they are touching the electrode completely pinch shut and both plugs in the 6th cylinder one plug in the 1st cylinder and one in the 4th cylinder , the spark plugs were replaced at the dealership so I assume they are the right plugs used if helps will post brand and number tommorow after work
Never assume the dealer has the remotest clue. Hope the piston tops are OK. Bet not.
Old 01-20-2009, 07:20 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
Clear cut sign of DETONATION!!!
That is why 89oct is recommended
Old 01-20-2009, 11:04 PM
Redone4x4's Avatar
Redone4x4
yes, pre-detonation is what i was told causes this. just between you and I, I had run 87 for a few months in the summer during high fuel prices. not anymore, its 89 or I dont drive it. mine was still fixed under warranty though. If you ask me, only fixing one or two cylinders seems like a bandaid though, but I couldnt talk em into a new engine. i tried lol.
Old 01-21-2009, 08:04 AM
ce2flaco's Avatar
ce2flaco
ce2flaco is offline
89 or better is all i ever run...EVER.
I had one of the first Hemi's out in 03 and from what i'm hearing, part of the problem was design. From what i understand the later Hemi's are improved in this area.
Anyone agree or disagree?
Old 01-21-2009, 10:53 AM
FrostKing's Avatar
FrostKing
FrostKing is offline
and there should be no wear on the engine it is a brand new engine it had to be replaced under warranty due to the same problem , I run straight pipes off my engine and have a cold air intake and a hi flo catalytic converter
Your engine is blown from running lean. If you are using a handheld tuner, then that made you leaner and boom. Chrysler engines do not adjust from increased air flow like Ford and Chev do. SD vs MAF
Quick Reply: flatten spark plugs
