K&N CAI Rattling
Old Jan 21, 2009 | 08:29 PM
65sportfurious's Avatar
65sportfurious
Ok so I figured out it is the actual air filter is hitting the inside of the fender. I twisted it slightly so its harder to hit it, but it just seems too long. I took it off and tried to make it go in farther, but its all there is. Anyone else had any clearance issues?
Old Jan 21, 2009 | 08:31 PM
nickahern1's Avatar
nickahern1
just cut the tube back a little more. and your good to go.
Old Jan 21, 2009 | 10:24 PM
badblackram06's Avatar
badblackram06
i had that problem on my cai also. so i just took some 3/8 in fuel hose and split it down the middle and stuckwrapped it on the inside of the circle where the intake tube goes through and it solved my rattle problem. sorry didnt read your last post
Old Jan 22, 2009 | 12:21 AM
65sportfurious
Well I made some adjustments tonight. I loosened the tube where it connects to the throttle body and just set the tube at a little higher angle so it didnt hang so low. hopefully that will solve the problems. I could cut it back as well, I'll try that it if it doesnt solve my problem
