K&N CAI Rattling
Old Jan 18, 2009 | 07:13 PM
65sportfurious's Avatar
65sportfurious
Default K&N CAI Rattling
So I installed my K & N CAI on my 08 hemi a few weeks ago, and now when I'm idling I notice that it rattles quite a bit. Has anyone else noticed this? I think I have the brace bar in the right place, but it just seems loose. All the brackets are tightened, but it just doesnt seem on right. Its rattling in the hole of the heat shield. Any help would be great if you have had that happen and how you fixed it.
Also if there are any pictures on where the brace bar goes, just to make sure I have it in the right place.
Old Jan 18, 2009 | 07:21 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
You'll notice more noises with a CAI...you could be hearing resonation from the EGR. Check your CAI to make sure there's not anything obviously loose or hitting anything.
Old Jan 18, 2009 | 07:24 PM
HammerZ71's Avatar
HammerZ71
Mine will move within the hole in the shield but not enough to contact the sides, so no noise. Recheck the supports. If all is fine, get you some heat resistant foam and wrap the tube where it goes through the hole, should solve the problem...
Old Jan 18, 2009 | 07:28 PM
SeMiGoD's Avatar
SeMiGoD
Are you sure thats the cause of the rattle? If you cant move it id say thats not the problem. If you can move it, by seeing where it moves id say its easy to see where to tighten it up.
Old Jan 18, 2009 | 08:57 PM
draco8494's Avatar
draco8494
yeah ide listen to it idleing with the hood open to determine whats making the rattle...and if it is the CAI then redneck it like hammer said, with some duct tape!! lmao
Old Jan 18, 2009 | 11:20 PM
hugekikd 2007's Avatar
hugekikd 2007
I have not had a problem with mine. If u think it is the tube hitting the heat shield you should put a piece of rubber their. Did this to my bros 300c and it worked.
Old Jan 19, 2009 | 02:14 AM
65sportfurious
where did you guys screw in the support member? for the life of me i couldnt figure it out from the picture. i screwed it into the front screw where i had taken off the hemi hat, seemed like the only place it would go.
Old Jan 19, 2009 | 02:48 PM
V_Scapes's Avatar
V_Scapes
that was the part that confused me, so i also bolted the arm onto the open hemi hot hole...heres a pic if this helps.
truck001.jpg?t=1232394441
you cant really see the whole support arm but it goes behind the tube.
Old Jan 19, 2009 | 03:06 PM
65sportfurious
That helps thanks. Looks like I got it all rigt and tightened down. Maybe I'll go tighten more
Old Jan 19, 2009 | 03:30 PM
V_Scapes's Avatar
V_Scapes
yea keep checking on it every couple of weeks since its new and keeo the screws tightened.
