Final Gear Questions
Old Jan 29, 2009 | 09:56 AM
fox_racer627's Avatar
fox_racer627
Default Final Gear Questions
After some research I finally decided on getting some Yukon 4.56 gears and a moes performance master install kit. Is there anything else I need to get or need to know before I order these? I am kind of tight on money right now so I just want to be sure thanks
Old Jan 29, 2009 | 10:15 AM
HammerZ71's Avatar
HammerZ71
2WD? Then no, just a ring & pinion and a master install kit. Oh, and a good installer... and I'm assuming you or your installer would know you'll kinda need gear oil & RTV, twice! Once now and once after your 500 mile break-in...
Old Jan 29, 2009 | 11:30 AM
fox_racer627
Yea it's a 2wd. I knew about the oil and gasket but thanks anyways for the conformation.
Old Jan 29, 2009 | 11:46 AM
fox_racer627
Stupid question maybe, but I will still be able to use the factory LSD correct?
Old Jan 29, 2009 | 11:54 AM
HammerZ71's Avatar
HammerZ71
Yes, but I'd consider replacing it with an Auburn Gear LSD at the time of the gear install. You probably won't get charged any additional labor if you do it then, and the factory LSD is a KNOWN time bomb. If/when it goes, odds are it will take your nice new 4.56s out with it.
Plus, if you are doing the gear change for "off the line", the Auburn will "hook up" a hundred times better than the stock LSD...
Old Jan 29, 2009 | 11:58 AM
yhike's Avatar
yhike
I agree get rid of the factory lsd and go with a Auburn or the DTT
Old Jan 29, 2009 | 03:18 PM
fox_racer627
I thought lockers werent good for street??
Old Jan 29, 2009 | 03:27 PM
yhike's Avatar
yhike
The only thing I notice on my Jeep is the backlash. You get a clunk when starting out and when shifting in lower gears. Not a big deal though, you learn to drive differently so it doesn't do it.
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
they aren't. auburn and dtt aren't lockers, they are limited slips just like the factory unit, but they are better, and not grenades either
Old Jan 29, 2009 | 03:29 PM
HammerZ71's Avatar
HammerZ71
Grasshopper, you are learning well...
