How good is the stock stereo???
i was looking at the specs on the 06+ factory stereo and saw the power output was like 66 watt because i saw it for sale here
http://www.automotiveconcepts.net/st...uct_43439.html
i know that aftermarket stereos put out like 50 watts so there has to be a mistake, right?
someone who know these things just tell me truth- thanks
i was thinking about upgrading my speakers and putting in a sub but i wasnt sure if the factory stereo could take it
Well I'm not sure if the specs are correct, but even if it is, power isn't everything. Just because a stereo puts out more power doesn't mean it's "better." There are more features to be found on aftermarket, and the clarity can also be different, among other things. Personally, I'm fine with the factory head unit (although I did swap my REF for an RAQ, but that's just because I liked the features better). I'm not an audiophile, and to me the system meets my needs - it plays CDs, gets radio stations (Sirius and traditional), and I can listen to my iPod with the Monster FM Modulator.
The factory head units don't have a line out on them, so it would be more difficult to connect an amp to it than an aftermarket. I'm sure it can be done somehow, but with a standard aftermarket, you just use RCA cables between the head unit and the amp.
Swapping out the speakers would still be ok, even if you don't add an amp. However, if you have the Infinity system, that complicates things as well. I've never done it so I can't help you with any upgrades. Good luck.
I have the Infinity system, I love it. 6 disc in dash changer, and its plenty loud for me. sounds really clear for passengers in the back seat also. I was told though, that adding a sub would be worthless without an amp. and they also said i needed a new head unit to install an aftermarket amp as well. dont know if that is correct or not, im not an audio guy either...
I added an amp and subs to my factory radio. I’m not an expert on car audio or anything; I have a friend that has a shop. But when he installed my amp, had to use a line out convertor, I think it’s called. It attaches to whatever speaker has the bass, in my 06 with the Infinity system, it was the front doors. The convertor connects to the amp.
Before I bought my in-dash, I was using the factory stereo.
I do have an amp, and subs in the truck...i was bought an equilizer and tapped into the stereo to get the left/right for the RCAs...the EQ i bought allows the user to modify and change the settings...you know cause the factory stereo doesnt have an option for the subs...
they sell an small device to make the RCAs...it taps into the stereo harness...the EQ that i have does the same thing, but allows you to manipulate the sound.....
just my two cents
just my two cents
I've done just what you are asking, pretty much how was explained above on my Dodge Neon. I kept my factory head unit, and tapped the factory speaker wires with line-out converters, which then enabled me to patch RCA cables to my amp. I find the factory stereo to be more than adequate. I personally like the clean look the factory stereo offers over many of the junky looking dash kits. I plan to do the same on my truck, though that will be a bit trickier. I'll probably tap the factory wires directly behind the receiver, as I'm planning to mount my amp under the driver's seat. With the speakers in the doors, I'm not sure how hard it would be to gain access and run them back to the amp.
One plus to this setup, you won't be a target to car audio thieves.
Trending Topics
WHat do you guys think of this stereo:
http://reviews.cnet.com/gps/eclipse-...in;contentBody
I like the fact that it is clean, non-flashy and doubble tall so it does not leave a gap where the factory stereo was.
Also offers navigation at no extra dashboard real estate.
http://www.sonicelectronix.com/item_...B+iPC-106.html
but if you like that one its way cheaper here.
http://www.sonicelectronix.com/item_...+AVN2210p.html
