Need to drop a Big Horn
Old Feb 2, 2009 | 08:27 PM
Terberta's Avatar
Terberta
Default Need to drop a Big Horn
I moved and want to get in the garage. I need to come down 3". Any ideas???
Old Feb 2, 2009 | 08:29 PM
sos's Avatar
sos
Get a shovel, or a sawzall. Seriously though, I'd modify my garage before I lowered my truck. Or I'd just park it outside.
Old Feb 2, 2009 | 08:38 PM
irelandshemi's Avatar
irelandshemi
just take all the air outta the tires get several inches outta that, naw but i would modify my garage like sos said before i would lower my truck unless i actually wanted it lowered
Old Feb 2, 2009 | 08:41 PM
hemiyellow's Avatar
hemiyellow
DC Insider
sounds like ur parkin it outside or building a bigger garage
Old Feb 2, 2009 | 09:03 PM
04-fourseven's Avatar
04-fourseven
hahaha, thats funny.
My dad bought an expedition right when they first came out, and when he got it home, he went to park it in the garage, and it wouldnt fit. He had to spend 1500 dollars just getting a new garage door put on. (the roll up type gave him just enough clearance to get the truck in)
Old Feb 2, 2009 | 09:07 PM
dodgenitto's Avatar
dodgenitto
Agreed, Get an 8' door for your garage. You can do it yourself for pretty cheap.
Old Feb 2, 2009 | 09:15 PM
MikeHTally's Avatar
MikeHTally
I was gonna contribute the "air outta the tires" answer.
Old Feb 2, 2009 | 09:58 PM
Rojhan's Avatar
Rojhan
Getting the door changed may be cheaper than modifying the truck.. and you keep the truck the way it is!
I have about 1/2" clearance between the top of the truck and the garage door. With a "speed bump" to keep water out of the garage, I have to take it very easy or I will bounce into the door frame.
Old Feb 2, 2009 | 11:07 PM
raminator08's Avatar
raminator08
is the actual ceiling inside the garage too low or is it the door because if its the ceiling, a new garage will cost some serious $
i would just buy a cover for the car. the only thing that would be a hassle is putting on and taking of the cover. or you have driveway room, just build a carport for less than a grand
Old Feb 3, 2009 | 12:59 AM
dirtydog's Avatar
dirtydog
Moderate User
Inside cieling height of garages is ALWAYS taller than the door itself. A door needs room above for frame work and roll up.
Maybe you can tighten your springs so the door gets pulled up a little more for enough clearance? If the truck just doesn't fit in height, it's an old garage and prob not long enoughas well or just too skinny like my bays on my detached. Did you check the length?
