decided against high output alternator....
Old Feb 5, 2009 | 09:08 PM
Romeosoldier03's Avatar
Romeosoldier03
Default decided against high output alternator....
too many poor reviews on them....if u get one u need to adjust ur idle to 8-900 rpm's....other wise everything dims down at idle...not paying 300 plus dollars for that....I see that dodge offers 2 alts for our 06 ram hemi....136amp and 160.....I dont know wat models have wat......Im assuming i have 136amp but i guess i outta go see if it says it on mine....my voltage is getting below the middle line at idle now......
Old Feb 5, 2009 | 09:13 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
what is dropping your voltage so low?
Old Feb 5, 2009 | 09:19 PM
Romeosoldier03
I believe my alternator is going out on me... it's got 115K on it plus I got kenwood screen, rear camera, amp, 2 mtx 10" subs so I think it's about time
Old Feb 5, 2009 | 09:29 PM
MikeHTally's Avatar
MikeHTally
Good information re: idle setting. Sounds like it's time for a battery, though. Will the 160ah fit in the 136ah mount? I considered this for a F-150 I had one time, but the mount was the cost of a battery. Chose to just deal with changing the battery every year or so.
Old Feb 5, 2009 | 09:51 PM
Romeosoldier03
the battery is only 6 months old and it's the high performance gell ones...optima
Old Feb 5, 2009 | 11:05 PM
SuperCar1of1's Avatar
SuperCar1of1
When did Optima start making Gel Batt's, I thought they only made AGM(absorbed glass mat) Batt's?
Old Feb 5, 2009 | 11:07 PM
Romeosoldier03
i was told it was a form of gell....my bad.
Old Feb 5, 2009 | 11:23 PM
dirtydog's Avatar
dirtydog
Moderate User
High Output Alternators do tend to use a bit of juice at idle. They tend to drain power when run under 800rpms. Anyways, I opted and chose a Batcap. My light don't dim ever and it's reserve is excellent. I have a 3,000watt system. Not a flicker in a light. My Hellas are as bright with the truck off as they are on. 100w bulbs. My batcap is now 4yrs old. Works perfect.
Here's the link http://cgi.ebay.com/Xstatic-Model-300-BatCap-Battery-Cap-Farad-New-2008_W0QQitemZ130259590627QQcmdZViewItemQQptZCar_E lectronics_Parts_Accessories?hash=item130259590627 &_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A10|39% 3A1|240%3A1318
