cb radio help
Old Feb 12, 2009 | 08:22 PM
02Steve1990's Avatar
02Steve1990
Default cb radio help
Hey everyone, I am planning on putting a cb radio in my truck and I am not sure if this will work so I am just wondering if any of you cb radio owners out there will know the answer...
I just bought these two items on ebay (cb radio and a cb radio antenna)
http://cgi.ebay.com/New-Cobra-19-Ult...3A1%7C294%3A50
http://cgi.ebay.com/CB-Radio-Aerial-...3A4%7C294%3A50
My question is..on the antenna description it says that the antenna has a SMA connector that goes into the cb...does anyone know if that Cobra cb has a SMA connector so I can connect that antenna?
Thanks for any info
Old Feb 12, 2009 | 08:48 PM
SeMiGoD's Avatar
SeMiGoD
Should be good to go with that.
Old Feb 13, 2009 | 04:36 PM
ramhunter9's Avatar
ramhunter9
10-4 0n that also
Old Feb 13, 2009 | 07:41 PM
WhiteBerry's Avatar
WhiteBerry
looks good!
good luck with the CB! check out www.cbradioforum.com sometime!
Old Feb 14, 2009 | 12:39 AM
Ram4wd's Avatar
Ram4wd
I checked a couple of things out.
Your antenna has a SMA connector and your Radio has a SO-239 connector. They are not directly compatible; different sizes. You will need an adapter; if one is available.
Also, magnetic mount antenna's are hard to adjust to for a good SWR; this will restrict your operational range.
On a positive note, here are links to a solid mount option that fits most of our trucks. There are two versions, a narrow and a wide.
http://www.genosgarage.com/prodinfo....CB_MOUNT_0305N
http://www.genosgarage.com/prodinfo....CB_MOUNT_0305W
Good luck!
Old Feb 14, 2009 | 07:12 AM
02Steve1990
where do you think I can find an adapter, and do you know how much they can go for?
Old Feb 14, 2009 | 08:01 AM
WhiteBerry's Avatar
WhiteBerry
just google cb radio, you will get a hit with sooo many sites that have accessories!
Old Feb 14, 2009 | 10:44 AM
Redone4x4's Avatar
Redone4x4
I would go with a different antenna. Wilson should make a magnetic one, and its probably SWR adjustable. thats the way to go if youre going to go magnetic. I have personally owned them and they worked the best out of alot of magnetics i tried. it will have the right connectors on it. while researching this for ya, i came across alot of bad reviews for the cobra 19...just lettin you know.
Old Feb 14, 2009 | 01:42 PM
02Steve1990
what were the bad reviews saying about it?
