problems with 05 hemi
Old Feb 18, 2009 | 11:09 PM
mmac1318's Avatar
mmac1318
Default problems with 05 hemi
I am having some issues with my truck bogging down and stalling. I notice it MOST when I am holding at 1 speed between 20-35 mph but I can tell it is doing it on the freeway too just not as noticable. It doesnt stall that often definately not everytime I drive it. I feel some hesitation when I start going slowly also. It started about a month ago I hoped it was ice or water but I ran 3 cans of iso heat through and didnt solve it so I was thinking it was a injector so I ran a can of lucas inj cleaner through it and then a can of sea foam still no luck. Tonight I changed the plugs I didnt really think it was the problem but it was time anyway. The engine light is NOT on so I am out of ideas. I think I am going to have to go to a dealer unless you guys can help. Thank you in advance.
Old Feb 19, 2009 | 12:30 AM
hemiyellow's Avatar
hemiyellow
DC Insider
pull the TB off and clean it up...might help out
Old Feb 19, 2009 | 12:40 AM
lenmat's Avatar
lenmat
I have had the exact same problem. We believe it is the IAC, so the dealer had to put in a new throttle body. I am hoping this fixes it, but wont know for a little while as it stalls randomly. Appearently this is the faulth of the 05, but they wont recall it. not very happy with dodge right now
Old Feb 19, 2009 | 12:47 AM
hemiyellow's Avatar
hemiyellow
DC Insider
i haven't had any problems like this in mine...didn't have it on my 04 either......how many miles yall got on your trucks???
Old Feb 19, 2009 | 12:52 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Hemi's don't have a IAC valve...the pcm uses the throttle blade to control idle. If you take the baffle off the TB you'll see the blade cracked open at idle.
Clean the TB like hemiyellow said
Old Feb 19, 2009 | 01:54 AM
mmac1318's Avatar
mmac1318
I've got about 53,000 miles on it.
OK dumb question but what is the TB and where is it?
Old Feb 19, 2009 | 02:03 AM
irelandshemi's Avatar
irelandshemi
its under the big box that says HEMI on it if you have the hemi dont know what it says if you dont have the hemi but big black box under your hood above your engine
Old Feb 19, 2009 | 07:55 AM
JoeHemi's Avatar
JoeHemi
yea I got some pics at this thread
It's the circular device with the orange ring around it.
Old Feb 19, 2009 | 08:24 AM
Cole's dad's Avatar
Cole's dad
Maybe your convertor is starting to block up. Does your truck run hot at all? Usually if your convertor is blocking it will run hotter. If it gets any worse maybe have your fuel pressure checked. Just some ideas.
Old Feb 19, 2009 | 10:10 AM
mmac1318's Avatar
mmac1318
Thanks good post I will try and check that out today.
Coles Dad to answer your question no problem with over heating or even getting a little hot. Thanks.
