Tow/Haul vs OD off
Old Feb 20, 2009 | 11:27 AM
Ram4wd's Avatar
Ram4wd
"SeVeReDiStOrTiOn" had it exactly correct.
This is directly from my 06 manual:
"TOW HAUL” mode, 5th gear (if equipped) is disabled
and 2-3 and 3-4 shift patterns are modified. Shifts into
Overdrive (4th gear) are allowed during steady cruise
(for improved fuel economy) and automatic closed throttle
downshifts to 3rd gear are performed (for improved
braking) when driving conditions warrant. Pressing
the “TOW HAUL O/D OFF” button a second time to
select O/D OFF will disable 4th and 5th gear completely,
which should eliminate any excessive transmission shifting."
I know, especially at highway speeds my transmission will hold in 4th for several minutes before shifting into 5th; in standard mode. Keep in mind also that the computer will hold the transmission back while it is cold and it takes a minimum of 5 miles of driving to get the transmission fully warmed up.
I would ensure that the transmission IS fully warmed up, and maybe then some, and then check it out again. If you feel it still doesn't follow the above from the manual, then you may want to get it checked out again. But, Mozzer, you were a bit off on your perception, at least as I read your original post.
Give it a try again and good luck!
Old Feb 20, 2009 | 11:43 AM
Ridinhigh's Avatar
Ridinhigh
Originally Posted by dirtydog
You do not lose any gears with Tow/haul, just shift points and firmness as well as auto/downshift when you touch your brakes. Helps when going down a hill pulling a heavy load.
O/D off means exactly that. Just knocks out the last gear, not 2, just one.
Can't put it much better than that O/D off just gets ride of 5th not 4th
Old Feb 20, 2009 | 11:46 AM
mozzer's Avatar
mozzer
Default 2008 tow/haul
Thanks a lot for the input, I would like to hear from anyone with an '08 just in case they have changed something for the worse in the programming.
Old Feb 20, 2009 | 12:38 PM
Matt99's Avatar
Matt99
My 07 seems to do as it should with O/D Off and Tow/Haul. You definitely notice a difference in Tow/Haul and if you accidentally leave O/D Off on? while going down the highway, you can hear your engine screaming at you.
And I was wondering about that whole "holding back the tranny" thing. I seem to have a hard problem getting into 5th sometimes, even when getting on the interstate. Its like I have to MAKE it shift. I know yall have a good explanation on this. By the way, I live in Louisiana so its never cold
Old Feb 20, 2009 | 01:06 PM
mozzer's Avatar
mozzer
Yeah I think the OD off is working fine, shifts up 3 usual gears then lock up the TC. But the tow/haul is no different.
So were up to an 07 with all behaving as it should, any 2008s ?
Old Feb 20, 2009 | 01:09 PM
dirtydog's Avatar
dirtydog
Moderate User
Mine is an '08.
I never had any trouble even when cold shifting into 5th on the highway. Actually it will shift into 5th with ease and sometimes I knock it out because it lags the engine.
Tow/haul just holds 4th gear for super long before shifting into 5th on the highway so you don't keep on downshifting constantly.
Here's Chryslers words.
DUAL-MODE TOW/HAUL FEATURE
The 2006 Dodge Ram 1500 also offers a “Tow/Haul” feature that provides crisp shifts and reduces gear searching, and an “Overdrive Off” mode that delivers maximum trailer towing performance. These systems will also select a lower gear in downhill conditions in order to utilize the engine’s braking capability.
I can drive empty on the highway in Tow/haul and it will hold me back when going down a hill. It helps out alot. I use O/D off when running 55mph on back roads. My truck wants to drop t in 5th gear??? 55 is too slow for 5th to me on hilly conditions.
Old Feb 20, 2009 | 01:34 PM
Matt99's Avatar
Matt99
New pic, seeing how it looks....too big or small?
Old Feb 20, 2009 | 01:44 PM
dirtydog's Avatar
dirtydog
Moderate User
Perfect.
Old Feb 20, 2009 | 04:07 PM
mozzer's Avatar
mozzer
Thanks a lot, so surprise sur f***ing prise the dealer doesn't know what he's talking about, I'll try a different one down the road.
Cheers.
Old Feb 20, 2009 | 05:28 PM
06CountryBoy5.7's Avatar
06CountryBoy5.7
no problems here, i have an 06'
