Violent Shaking and wheel torque specs?
Hey guys. Brought my truck into the shop today because my truck shakes at 60+ mph. It stops around 70.
They balanced all the wheels and put them back on with 95 ft-lbs of torque.
1st question: What is the wheel torque specs for a 2006 ram 1500 qc hemi?
I can't seem to find them. Is it the same as the 2005's at 135 ft-lbs?
I thought 95 was low but I'm just trying to get the right number.
Anyways, after I left the shop with newly balanced wheels I took it on the highway. Got up to 60 mph and my truck shakes even more! So I brought it back, they re-checked the wheels and they were fine. So now my truck violently shakes at 60+. Any ideas? Could it be that the wheels are torqued too low and therefore shaking because of that?
and i have my wheels torques to 135 ft lbs!!! 95 is waay to low imo! the owners manual says 135
check your alignment. just had the same issue with my 04. i had my rackand power steering pump replaced, check your tires too, those stockers are garbage. definatly have the alignement looked at though.
Since I'm under warranty I'm gonna bring it somewhere and let them have fun scratching their heads. It's insane how many things it could be.
It's a really bad vibration though all over the entire truck. I'm just amazed it got worse AFTER I balanced the wheels.
hey im a diesel mechanic and from what ive seend it could be a wheel bearing, your alignment, or driveline vibration. check for loose u joints, or loose inputs going into your axle and transmission from the driveshaft. if its 4 wheel drive you can check the front driveshaft going from the transfer case to the transmission.
Trending Topics
I'm thinking about bringing it somewhere else because they actually checked them twice. Their machine might be wrong.
