factory jack
Old Mar 9, 2009 | 10:36 AM
dutter's Avatar
dutter
Default factory jack
just wanted to tell all with a 1500 truck. be very careful when using the factory jack. i used mine this weekend (floor jack was broke), when i was finished using it i noticed one of the lower pins that hold the jack together was allmost out completly. the pins should be mushroomed at the one end, the one was not. just check your jacks out before you use them, it could be a nightmare if one failed.
Old Mar 9, 2009 | 11:50 AM
SeMiGoD's Avatar
SeMiGoD
I carry a bottle jack in my truck and at home i have 2 floor jacks. Ive NEVER used any factory jack.
Old Mar 9, 2009 | 11:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The one time I used my factory jack I got it done but it barely went up high enough for me to change the tire and even then I ended up bending it. Ever since then I keep a hydrualic jack in the truck. The stocks suck big time.
Old Mar 9, 2009 | 12:00 PM
ramhunter9's Avatar
ramhunter9
i cant use the factory jack it wont be high enuff i carry a floor jack and stands in the tool box
Old Mar 9, 2009 | 12:02 PM
dutter's Avatar
dutter
its a good idea to use a bottle or floor jack, although the warning is for some who may need to use it.
Old Mar 9, 2009 | 01:02 PM
Redone4x4's Avatar
Redone4x4
be prepared to not use it, is what people are getting at. I used mine once in an emergency, and it bent. Just barely got it done, and it was dangerous as all hell. They are pretty much disposable, so now there is a 5 ton bottle jack in my truck as well. I would say that anyone that doesnt have a stock jack alternative should find one so they dont get stuck on the side of the road with a busted stock jack and no alternatives at that point. just my $.02
Old Mar 9, 2009 | 02:47 PM
TRXHemi's Avatar
TRXHemi
WOW - good info. I will get another to carry along.
Old Mar 9, 2009 | 03:09 PM
dedogg's Avatar
dedogg
yeah thanks for the info
Old Mar 9, 2009 | 03:12 PM
dedogg's Avatar
dedogg
yeah thanks
Old Mar 9, 2009 | 03:29 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
i've used mine multiple times, from actually changing a tire to lifting it to put on ajck stands to do brakes. even pulled mine out when my brother had a flat. no complaints with it here.
