Has anyone solved an ABS Light, Brake Warning Light, No Speedo symptom?
#31
Check out your ignition switch. mine was doing the same thing. I jiggled the keys while on the run position with the key and they the heater and radio worked and all the power mirrors. I replaced the ignition switch which was very east to do and that problem was fine. I know have the ABS light and brake light on. i changed all the sensors and still on. I found that the drivers side wheel sensor has no circuit that is telling me the ABS module is bad. I found a good used one with the same part number listed on the top of it and i am in the process of replacing that.
#33
#34
Yep, 04 ram 1500, There's a residual "charge: left in computer. Pull battery a cple of hrs should do the reset(it did for me) but do a overnighter?
