Installed my Hellas???
Old Mar 22, 2009 | 12:20 AM
  #41
southernbnb's Avatar
southernbnb
when i wired mine at first i said forget the instructions and just tried to straight wire them. after several hours i picked the instructions up and followed them and they worked perfectly. so all i can tell you is follow the instructions to the letter. hope you get them working.
Old Mar 22, 2009 | 12:21 AM
  #42
Rebeltilldeath3's Avatar
Rebeltilldeath3
And for future reference, so that diagram doesn't confuse anyone, this is the correct way to wire a four post relay. Although there are some oddball ones out there.
Old Mar 22, 2009 | 12:23 AM
  #43
Alpheus's Avatar
Alpheus
The diagram is just taking away the ground instead of the hot wire...
Old Mar 22, 2009 | 12:24 AM
  #44
raminator08's Avatar
raminator08
Originally Posted by Off_Road_Teacher
Just don't drive at night, then no one will wonder why you aren't using your new lights
even better idea, just stick a couple of flashlights behind the grill to give the illusion that they are working
Old Mar 22, 2009 | 12:30 AM
  #45
SilverBullet08's Avatar
SilverBullet08
been using the instructions man
Old Mar 22, 2009 | 12:32 AM
  #46
SilverBullet08
ok u can see my relay in the second pic top left. so it sounds like i need to ground the relay then ill be good??
Old Mar 22, 2009 | 12:51 AM
  #47
Alpheus's Avatar
Alpheus
I don't see any pics but yes ground the relay and you will be in business.
Old Mar 22, 2009 | 12:53 AM
  #48
SilverBullet08
ok and on the first page
Old Mar 22, 2009 | 01:07 AM
  #49
Alpheus's Avatar
Alpheus
OK, I see 3 wires might be 4 but is there a zip tie on there???
Old Mar 22, 2009 | 01:13 AM
  #50
SilverBullet08
no zip tie...
