Installed my Hellas???
Old Mar 21, 2009 | 07:06 PM
SilverBullet08's Avatar
SilverBullet08
Default Installed my Hellas???
ok well i installed my hellas or atleast tried too. i followed all the instructions and thought i did it right but they will not turn on. any advice please...
Old Mar 21, 2009 | 07:10 PM
raminator08's Avatar
raminator08
sorry that they dont work and i cant help you there but id thought that id just say that they do look nice though
Old Mar 21, 2009 | 07:12 PM
nim81's Avatar
nim81
looking good..
have you double checked all the fuses? all the connections, and double checked all the insturstions
did you run a wire to the highbeams or not?
if not you need to run the green(if i remember right) wire to the hot post on the battery
Old Mar 21, 2009 | 07:13 PM
SilverBullet08
Originally Posted by nim81
looking good..
i double checked all the fuses. i did not run to the highbeans you can see in the second pic i run the green wire from the relay to the switch. is that wrong? the red wire is from the battery to the relay...
Old Mar 21, 2009 | 07:29 PM
mxzrevman's Avatar
mxzrevman
check the ground
if the ground isnt good it wont work at all
even if its on metal thats not a true ground, nota
Old Mar 21, 2009 | 07:37 PM
nim81's Avatar
nim81
Originally Posted by mxzrevman
check the ground
true true,
i ran all my grounds to the neg batt.
SilverBullet08:
i just checked mine , the red wire is ran to the relay and pos. batt. and green wire is straight from switch to pos. batt..
the green wire on mine isnt ran to the relay.
Old Mar 21, 2009 | 08:10 PM
Alpheus's Avatar
Alpheus
Dont use the wire color codes they could be wrong because the colors were different from what my instructions said. Look at the bottom of the relay you will see numbers.
#87 goes to the Hellas
#86 goes to the high beams
#85 goes to ground
#30 goes to positive battery terminal
Can you hear the relay clicking???
Old Mar 21, 2009 | 08:59 PM
SilverBullet08
ok i have my ground wire on the crossmember. all my wires are wired like above but i didnt use the highbeams just the switch. i dont know what to do...
and no i cant hear the relay clicking. it doesnt make any sound
Old Mar 21, 2009 | 09:02 PM
nim81's Avatar
nim81
then the highbeam wire should be connected to the postive battery post.
Old Mar 21, 2009 | 09:12 PM
SilverBullet08
what color is that?
