homemade angel eye headlight
Old Mar 30, 2009 | 10:36 PM
Bigc9164's Avatar
Bigc9164
Default homemade angel eye headlight
this website tells how to make a homemade angel eye found on some bmw's.
http://www.geocities.com/crx_auto/eagle_eyes.htm
I made a pair for trial this weekend for my hella 500's behind the grill because i didnt want to open up my headlight housing to take measurements when i need to drive this week. i will prob finish up the whole thing over spring break next week.
The procedure told on the website works wonderfully!!!!!!! it looks amazing!! the only problem is that the LED bulbs i used were not bright enough to light up the whole ring because i was making a ring that was about 3 times the size as the one on the website due to the large diameters of the hella 500's as well as the ram's. so im getting an LED light that is 10mm instead of 5mm and is about 23 times brighter. so it should light it up like a christmast tree when im done.
ill definatly post some pics when im done with the intall of the hella 500's this week and see if i really want to open up my headlight to do the real headlighs. But it was very easy to do this though!!
BUT U NEED SOLID RODS not the hollow ones found on most blinds!!!
Old Mar 30, 2009 | 10:51 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
10mm LEDs will not fit in the blind rods and bigger isnt brighter. LED brightness is measured in MCD. I have a pack of 30 5mm white LEDs that are 55000mcd.
Old Mar 30, 2009 | 10:58 PM
Bigc9164's Avatar
Bigc9164
ya i know. im using a tube that wraps around the bottom of the rod on both ends that will allow the 10mm to fit snug and it a 98000 got them at radioshack for $6 each
Old Mar 30, 2009 | 11:18 PM
raminator08's Avatar
raminator08
good luck with it
you should definitely make a diy if you get the chance
btw, how much is the whole setup going to run you?
Old Mar 31, 2009 | 07:41 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Are you sure there isnt an extra 0 in those numbers because when I checked at RS they had nothing over 10k. Do you have a part number because I would be interested. 98k would be extremely bright. Also, did you do reflective tape on the back or tin foil?
Old Mar 31, 2009 | 07:45 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
i got a spare set of lights sitting at home to try this on.
Old Mar 31, 2009 | 08:36 PM
lxman1's Avatar
lxman1
Site Moderator
No comment
Old Apr 1, 2009 | 06:29 PM
Bigc9164's Avatar
Bigc9164
let me know the dementions of the rings if u can!
Old Apr 13, 2009 | 12:18 AM
Matt99's Avatar
Matt99
I am going to make the angle eye setup but for under my headlights this week. I will take pics after the install, I hope it looks as good as i have it pictured
Old Apr 13, 2009 | 10:05 AM
Bigc9164's Avatar
Bigc9164
i made a ring or two and it turned out perfectly accept for i need brighter LEDs to light up the whole ring because the rams headlights are sooooooo big!! ha
