Question about this CAI system...
Old Apr 3, 2009 | 11:37 AM
  #21
SilverBullet08's Avatar
SilverBullet08
you know they have "regular" cai on ebay that are the same price as that. you like the dual filter?
Old Apr 3, 2009 | 12:57 PM
  #22
chambers's Avatar
chambers
Originally Posted by weedahoe
As for everyones assuption of it pulling nothing but hot air, I have hooked up my SC3815 and watched the temps on the AIT and at idle, yes it can go up a bit but even at 20-25mpg I can watch them go back down.
Did you mean at 20-25 mph referring to temp. drop due to airflow?
Old Apr 3, 2009 | 02:34 PM
  #23
bolang's Avatar
bolang
I also have the twin air filter setup on my 4.7 and it is great.I have better mpg's and throttle is more responsive.
Old Apr 3, 2009 | 02:39 PM
  #24
bolang's Avatar
bolang
Nice train horns Weedahoe.
Old Apr 3, 2009 | 02:42 PM
  #25
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah but I bought this one a long time ago and its been there every since. I have cleaned the filters and Ive never had any issue with. The bad thing is that I cannot compare it to anything else because its the only one I have eevr had. And yes I do like it.
Yes, the you sit and idle your IAT temps rise but as you drive you have air flow come in through your front end of course and which pushes all the "hot" ait out and thus the intake sucks fresh air thats at the outside temps. With this you start to see the IAT temp numbers decrease.
Old Apr 3, 2009 | 10:50 PM
  #26
Seanutz's Avatar
Seanutz
I love the way it looks, I have never seen one in person and its something around here no one I know has, plus it looks way cool.
Thanks for the info Weedahoe!
Old Apr 4, 2009 | 01:14 AM
  #27
lxman1's Avatar
lxman1
Site Moderator
You are still getting heat from the radiator right on the filters while driving. Check your temps when it gets up in the 80's again and see how cool it is.
Even the factory knows to pull air from the sides or front of the engine compartment. Ford, GM and Dodge do it for a reason.
Old Apr 4, 2009 | 11:09 PM
  #28
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thanks. They sound better than they look. :-)
Youre quite welcome.
Oh I agree you can get cooler air from other places. But then were not in debate of who is running cooler. You if you are really asking for that data I can record it on the SC3815 and post it.
Old Apr 6, 2009 | 06:44 PM
  #29
Bigc9164's Avatar
Bigc9164
u might as well do it. CAI are the most over rated things ever. the computer will adjust for the change in temp over the stock one. thats why they put a temp sensor AFTER the air filter. and that would look cool. but i just spent 5 hours making one from PVC pipe and it works looks and sounds amazing!! and only cost $20
