Mopar Nerf Bars
Mopar Nerf Bars
Looking for a little help here. Bought a 2006 Quad Cab and then purchased some direct from the dealer Mopar Nerf Bars for it. The intructions that came with them are pathetic to say the least.
I was wondering if anyone can help me out here. They are suppose to mount to exsisting holes in the frame already. Tonight I started to look at how to install and realized that the braces that attach to the Nerf bar supports do not clearly fall into line with any exsisting holes in the trucks frame. The nerf bar supports are easy enough to install, it is just the brackets that attach to them that is the only issue. Was hoping someone here ran into the same problem, or might even possibly have a photo of some installed. Thanks for any info.
I wish the instruction came with a language on them instead of international "signs"...
Here are the instructions... http://www.mopar-accessories.com/en-....ashx?id=14364
They attach to the body, not the frame. Some of the holes are covered with tape and painted.
These are parts "E" and "G" in the diagrams at the bottom of the first page.
Wow, humm Ok I believe you, just did not see how it was possible, mind you I was only under the truck for like 20 mins just loose fitting stuff. Just did not see where those brackets would/could attach. Well let me ask you, they do not attach to the same body holes that are right next to the saddle holes do they? Seemed like the angle of those brackets wanted to reach up and attach to the bottom of the truck, thats why I was saying frame.
Will give it another go tomorrow evening.
