Tow Haul Dangerous????
Old Apr 7, 2009 | 08:05 AM
  #21
RubberFrog's Avatar
RubberFrog
4.56s are definately on the list!
Old Apr 7, 2009 | 04:20 PM
  #22
04-fourseven's Avatar
04-fourseven
With the vast mod list you have, im surprised you havent done it already. Im sure its moving up quite rapidly though huh!
Old Apr 7, 2009 | 06:08 PM
  #23
lxman1's Avatar
lxman1
Site Moderator
Ok here is the real deal on 5th gear.
Yes it is disabled in tow/Haul. I checked it on the highway this morning and again, this afternoon.
RESULTS with stock 275/60r20 tires and 3.92 gears MDS off.
65mph
Tow haul = 2000rpm
normal = 1800rpm
70mph
Tow/Haul = 2180
normal = 1950
There is not a big drop from 4th to 5th, but it is there.
Roughly a 200rpm drop.
Old Apr 7, 2009 | 06:30 PM
  #24
magnethead's Avatar
magnethead
65mph
Tow haul = 2000rpm
normal = 1800rpm
70mph
Tow/Haul = 2180
normal = 1950
1st 3.00:1
2nd 1.67:1
2nd Prime 1.50:1
3rd 1.00:1
4th 0.75:1
5th 0.67:1
http://wahiduddin.net/calc/calc_speed_rpm.htm
2000 RPM @ 0.75:1 @ 3.92 @ 16.5" = 66.8 MPH
1800 RPM @ 0.69:1 @ 3.92 @ 16.5" = 65.3 MPH
2200 RPM @ 0.75:1 @ 3.92 @ 16.5" = 75.3 MPH
1950 RPM @ 0.69:1 @ 3.92 @ 16.5" = 70.8 MPH
Old Apr 7, 2009 | 10:49 PM
  #25
davb673's Avatar
davb673
Originally Posted by dirtydog
I was asking if my truck never enters 5th gear regardless of tow/haul. With tow/haul on, I am at 1800rpms at 70mph. With tow off I'm at 1800rpms at 70mph?????? That's why I said tow mode doesn't turn off 5th gear.
Maybe there's something wrong with my truck because there certainly isn't a 500rpm difference between the two while I'm on a flat no winded highway.
It may be that the torque converter does not lock, if in tow/haul. I drove my truck 1200 miles out here to Utah, carrying another 1150# in it, and it ran fine. Got 18.8 mpg at 70mph. It's been too long since I did that trip, so I can't recall if it hit 5th or not.
[edit] nevermind, it seems I'm late...
Old Apr 8, 2009 | 08:22 PM
  #26
cqsox's Avatar
cqsox
I was doing 110mph in tow haul 4th gear around 5000 rpm
Old Apr 8, 2009 | 08:49 PM
  #27
04-fourseven
Thats true. When Im doing 148 with tow/haul on, im cruising at 1800 RPM...
Old Apr 8, 2009 | 08:54 PM
  #28
lxman1's Avatar
lxman1
Site Moderator
You must have 37" tires with 2.41 gears
Old Jun 6, 2009 | 05:38 PM
  #29
Robinhood65's Avatar
Robinhood65
My tow/haul light keeps coming on as I'm driving and it takes me out of overdrive. Any ideas? Thanks!
Old Jun 6, 2009 | 11:21 PM
  #30
lxman1's Avatar
lxman1
Site Moderator
Sounds like the transmission is throwing a code. Have the computer scanned. Sounds like a bad solenoid perhaps.
Shift points when in tow haul mode are delays from 2-3 and 3-4. 5th is disabled.
It will also downshift at highway speeds from 4th to 3rd when you touch the brake to help slow the truck.
Oh, by the way, welcome to the forum.
