foglights and highbeams on at the same time? (i know its on here somewhere)
Old Dec 25, 2011 | 02:39 PM
  #31
theice's Avatar
theice
here ya go if you need anything else just let me know
http://i1111.photobucket.com/albums/...137/img003.jpg
Old Dec 25, 2011 | 04:21 PM
  #32
lyndo's Avatar
lyndo
this will most likely work on a 07 ram correct? I think ill give it a try but if anyone knows of a reason it wouldn't let me know.
Old Dec 25, 2011 | 08:08 PM
  #33
theice's Avatar
theice
in theory it should work on any vehicle
Old Dec 25, 2011 | 08:32 PM
  #34
lyndo's Avatar
lyndo
alright well hopefully I'll get a chance to do it in the next few days here and I'll let you guys know
Old Dec 27, 2011 | 12:43 AM
  #35
boxerguy84's Avatar
boxerguy84
This works great, thanks a lot. And by the way, the high beam wire on the drivers side you need to splice into IS the White/Light Green one.
Old Dec 27, 2011 | 05:00 PM
  #36
lyndo's Avatar
lyndo
well I was looking at doing this today and I don't think its possible to do it on 06-08 rams. I was reading on another forum and they were saying that the pre 06' trucks use an Integrated Power Module (IPM) that uses a relays. 06' rams and later use a Totally Integrated Power Module (TIPM) that does not use relays and is not serviceable. Meaning that both the relay way of doing the fogs and brights as well as the jumper mod cannot be done to 06 and newer trucks, the only way to do it is buy one of the aftermarket modules.
Old Dec 27, 2011 | 05:20 PM
  #37
dirtydog's Avatar
dirtydog
Moderate User
No, not correct.
^^Correct. This mod cannot be done on any Electronically Intergated controlled vehicles. The Newer Rams 06+ have TIPM's (Totally Integrated Powertrain Module) ALL things are controlled through electronic relays via programming. Since everything is electronically controlled, they are ALL CANBUS operated. Canbus uses one wire for multiple operations and changing or adding anything to that circuit will cause electronic failure!!!
Relays are mechanical devices, a TIPM is a sensitive piece of electronics. Two different animals.
BTW, this has been already discussed within Hammer's thread which i believe is in the FAQ section?
Old Dec 27, 2011 | 05:24 PM
  #38
Cthulhu's Avatar
Cthulhu
Careful Dirtydog, I think signs of PTSD are showing.. Feelings such as dejavu and other 'flashback' sensations are common.
I concur with DD's post above.
Old Dec 27, 2011 | 05:51 PM
  #39
dirtydog's Avatar
dirtydog
Moderate User
I dont understand? I was only pointing out the quick truth of the differences. The quick situation that there is another more lengthy talked about thread incase they wanted(didn't have the link). And more-less that unless you have specific knowledge, you cannot just go connecting wires or adding relays...
I suppose using the search function or reading above posts did come to mind..haha, but I didn't want to be a jerk and soley point out those with no added help/info.
Old Dec 27, 2011 | 06:53 PM
  #40
boxerguy84's Avatar
boxerguy84
I initially followed that FAQ post to accomplish this but I wanted to still have the ability to control the foglights with the factory switch. It's a little more work but well worth it... Plus I got an excuse to buy a heat gun and soldering kit.
