My system setup...
Old Apr 13, 2009 | 01:31 PM
Hemi Firefighter's Avatar
Hemi Firefighter
Default My system setup...
hey guys..
i just wanted to check and see what you guys thought about this setup..
I am picking up a 12" kicker CVR from a friend for a great price..
and am going to probably go with this box.....
http://cgi.ebay.com/ws/eBayISAPI.dll...tab%3DWatching
and im still up in the air about which amp.. my goal is not to spend a fortune, but sound decent.. i figure i only really need a amp that will push 300ish RMS to give the kicker enough bump...
any thoughts?
also, real quick, does it matter if the sub is a 2 ohm or 4ohm when it comes to the sub?
(i am running stock Head unit with no plans of upgrading)
Old Apr 13, 2009 | 01:52 PM
Hoss356's Avatar
Hoss356
Yes, if the sub is 2ohm then you will need to make sure the amp is 2ohm stable. Generally speaking the lower the ohm value the less resistance or load the amp will see, and in turn produce more power. An amp rated at 150w @ 4ohms may very well produce 300w @ 2 ohms. Just make sure you get a mono amp and go with a quality name, a cheap amp can sound horrible. I'd find an amp rated around 350w rms @ 4ohms and you should be fine. Oh, and on that box, don't forget the poly fill.
Old Apr 13, 2009 | 02:29 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You didnt say if that CVR was a SVC or DVC. I have 2 CVRs in 2ohm DVCs. They are 400 rms and 800 max. Coincidently my amp is 800 rms and 1600 max.
So even with 300 rms I think you will be good.
Old Apr 13, 2009 | 02:54 PM
mfs212's Avatar
mfs212
Directed & Concept make affordable amps....I like my D1200 Directed Class-D for the subs, and I might suggest the directed D600. It is 300wRMS x1 and they are small and efficient. It wont produce much heat, and they sound good.
Here is one for $85 and ebay has them for $115. I have never shopped at gooddeals18, tho...
http://www.gooddeals18.com/product/D600?meta=FRG
Old Apr 13, 2009 | 03:04 PM
Hemi Firefighter
thanks for the help guys.. not sure what SVC or DVC means, and i still am not sure weather the sub is 2 or 4 ohms.. ill have to look at it when i pick it up from him.
and do you mean about the box, dont forget the poly?
Old Apr 13, 2009 | 03:18 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
damnit, every time i get into a thread about sound stuff people throw out so many damn numbers and acronyms and **** if feel like a f***ing retard. you know what, f*** you guys and your damn knowledge of sound stuff!!
/rant
Old Apr 13, 2009 | 03:22 PM
dirtydog's Avatar
dirtydog
Moderate User
SVC=single voice coil. meaning there is just one positive and one negative connector on the sub.
DVC=Dual Voice coil. Two sets of conections gives user more versatility with amps.
As far as 2 or 4ohm, generally the sub model would be something like 12d2 or 12d4 which would mean 12" sub 2 or 4ohm accordingly.
Poly is the teddy bear type stuffing that gets put into the box so the sub acts like it's in a bigger box. Has it's ups/downs, but primarily a benefit.
Old Apr 13, 2009 | 05:11 PM
Hoss356's Avatar
Hoss356
Thanks Dog, it's also been my experience that a sealed box filled with poly "hits" a little better down low.
Old Apr 13, 2009 | 05:39 PM
dirtydog's Avatar
dirtydog
Moderate User
Yes and no. if the box is already big for the specific sub, poly won't help. Also, when you go for that low frequency, you lose the high hitting bass. I prefer mid-low bass overall. With super low bass, people tend to crank the volume up so they can hear it better which heats up the voice coils and fries them. ESPECIALLY with cheaper equipment like the kicker CVR and ANY sub amp under $500 for the most part.
That Kicker will be mid-high hitting bass regardless of box dimensions. Not much low end kick that stands for anything. Those subs aren't meant for DB drags.
Old Apr 13, 2009 | 05:45 PM
mfs212's Avatar
mfs212
Yea...not going to win any competitions, but i dont think thats what we had in mind.
