I'm hating my mds these days....
Old Apr 24, 2009 | 08:18 AM
HammerZ71's Avatar
HammerZ71
Originally Posted by SeVeReDiStOrTiOn
Tuner preference sways on this site like no other..
I don't think so. The Diablo is a solid choice for the newer Rams, same as the SCT. But get into the 05< ones and they don't offer the choices, mainly transmission tuning, that the SC offers.
If you are referring to me, I've pretty much said that from day one...
Old Apr 24, 2009 | 08:32 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
No I wasn't refering to you specifically...more towards the site as a whole.
Old Apr 24, 2009 | 09:38 PM
TheFist's Avatar
TheFist
Man, 6500lbs shouldn't blow a gasket!
Old Apr 25, 2009 | 03:16 AM
lxman1's Avatar
lxman1
Site Moderator
It will with loose bolts
Hammer, here is the trans years according to their site
Shift Points, 05-08, 03-04 comming soon
Old Apr 25, 2009 | 07:52 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I wish they would get the 04's covered already, then I could justify switching over.
Old Apr 25, 2009 | 08:04 AM
HammerZ71's Avatar
HammerZ71
You and me both, 'teach. I got a cam in the garage waiting for a viable custom tune solution...
Old Apr 25, 2009 | 08:08 AM
Off_Road_Teacher
Well now I am starting to get ready for a cam install too and am in the same boat as you. If DSP doesn't come out with trans control I am going to have to stick with the SC and a cam that runs on it with a piggyback.
Old Apr 25, 2009 | 03:21 PM
UP_Boilermaker's Avatar
UP_Boilermaker
I'm not sure what the exact thread pitch & length is for your header bolts, but you should check these out. I've used them on a few different engine builds in the past with no failures.
http://store.summitracing.com/egnsea...5&autoview=sku
EDIT: Found the exact ones you would need:
http://moesperformance.com/index.php...e956da1771216e
Same ones cheaper here:
http://store.summitracing.com/partde...6&autoview=sku
Last edited by UP_Boilermaker; Apr 25, 2009 at 03:25 PM. Reason: Found exact match
Old Apr 25, 2009 | 06:54 PM
Cheeech's Avatar
Cheeech
Originally Posted by Romeosoldier03
i thought it was good....but just not enuff adjustability......
They run lean and you would be terrified if you ever ran your truck on a dyno! Luckily with your LT headers it richens the mix out a bit.
I tell people that if they go with LT headers.....An adjustable tuner is a must if you wanna be safe and get all power you can. can't change most on a dyno. Diablo and SCT are really the only options in my books. and SCT is really produced for Fords but work well with others. So I'll say you need to dump the current programmer and pick up a Diablo for adjustability or just get a superchips if your not gonna do any dynoing and turn that MDS off. That was the first thing I did. i didn't care which programmer I bought as long as it had the MDS delete. Now if they can only update the tuners for 2nd prime delete I'll be a happy camper!
Old Apr 26, 2009 | 03:09 AM
ramjamhemi's Avatar
ramjamhemi
Locking header bolts work great. If you really want to go the inexpensive route and have the bolts stay snug, put two regular FLAT washers under the bolt head. I learned this from an instructor that has done this since the 60's and he swears he does not have loose header bolts. I never had a header bolt loosen when using two flat washers for the six years I ran them.
