Gear oil question
Old Apr 27, 2009 | 05:22 PM
kevin03's Avatar
kevin03
Default Gear oil question
I've been searching threds for the correct gear oil and additive amount for my truck.If this is and old question I'm sorry for taking up space.I have an '03 2WD 1500 W/3.55 LSD gear.I really want to change the oil this weekend.Another question,synthetic or not?Could someone point me in the right direction.
Old Apr 27, 2009 | 05:28 PM
SilverBullet08's Avatar
SilverBullet08
synthetic. heres a link in the faq section. https://dodgeforum.com/forum/3rd-gen...gear-lube.html
you could also check the manual
Old Apr 27, 2009 | 05:33 PM
BEAR's Avatar
BEAR
+1 ^^^ also there are some synthetics that don't require the LS additive such as Royal Purple.
Old Apr 27, 2009 | 06:05 PM
kevin03's Avatar
kevin03
Thanks alot
Old Apr 27, 2009 | 07:54 PM
MikeHTally's Avatar
MikeHTally
75w-140. If you can afford it, get a PML (or similar) cover to increase the amount of oil, especially if you tow. ~2.2 qts of Mobil 1 and four ounces of additive if you keep the stock cover.
Old Apr 27, 2009 | 09:50 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yep. 75-140 of Mobile 1 here is about $19 a quart.
Old Apr 27, 2009 | 10:51 PM
davb673's Avatar
davb673
I'm using the same weight, but AMSOIL. Also, I don't need friction stuff with the LockRite...
Old Apr 28, 2009 | 08:00 PM
kevin03's Avatar
kevin03
I don't do any towing,just a daily driver.
Old Apr 28, 2009 | 10:53 PM
davb673's Avatar
davb673
Kevin, I don't tow much either, but the LockRite was a God-send this winter. It kept me from getting stuck 3 times, maybe more. I just threw 300# of sandbags in the bed and dropped the hammer as needed...
