any ideas on how to get the mechanical fan and clutch assembly off
im def not, cuz the hayes manual shows the listing for 3rd gen rams, and is clearly shows all 2002 except diesels have reverse threads, and i went to advance auto, autozone and a couple of local auto stores and no one has even heard of the spanner tool, everytime i got dumbfounded faces, well has anyone else had problems getting theres off, i need to know if its alright to just cut it off flush with the pulley, cuz if i try again (both ways!) and cant get it off, im thinking of just cutting it off, cuz this is just getting frustrating
berndog I have the haynes manual right here and it says "On all models except 2002 diesels, turn the nut counterclockwise to loosen it. On 2002 diesel models the nut has left hand threads..." So you need to put some bolts in the holes to span the gap, and have someone hold a crow bar or something in there to hold it still. Place a large wrench on the nut and hit it w/ a small sledge if you can't move it by hand turning COUNTERCLOCKWISE.
edit: If you need to check it's on page 3-6 in the middle column under step 13.
when i went to auto zone i asked for a spanner wrench and they looked at me funny also.Then i told them "you know,To get the fan clutch off".they looked at me funny somemore then it was like a light went off and they said"OOOHH a fan clutch removal tool" they gave me one for a ford the first time.the second time they gave me the right one
