any ideas on how to get the mechanical fan and clutch assembly off
Old May 4, 2009 | 06:13 PM
berndog67's Avatar
berndog67
Default any ideas on how to get the mechanical fan and clutch assembly off
by chance would anyone know of any ideas on how to get the mechanical fan and clutch assembly off, i pretty much spent the better part of my last day off trying to get it off and to no avail, it is a little rusty, just surface rust though, i put a huge 16" wrench on the nut part and used everything from a pipe clamp to regular clamps to a home made steel bar that was over 1/4 inch of flat high carbon steel with two bolts threaded though the pulley to keep it from moving and was over 3 feet long and that still was not enough torque to free it, i ended up bending the steel bar which i should never have been able to, and yes i know it is reverse threaded and used plenty of penetrating lube and wd40 and whatnot, but still wont come free, is there another way or could i just take and cut it off like halfway down the nut part, i dont want to have any problems is all, just want to be able to put on the darn electric fans i have sitting in my garage for the past week!
Old May 4, 2009 | 06:34 PM
dodge it then ram it's Avatar
I was able to get it off with a punch when I did my body lift. But it seems like you had more power on it than I did.
Old May 4, 2009 | 06:36 PM
nim81's Avatar
nim81
my 2002 5.9 isnt reverse threads
Old May 4, 2009 | 08:06 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
It's not reverse threaded on my truck. Sounds like you might be turning it the wrong way
Old May 4, 2009 | 08:08 PM
ramhunter9's Avatar
ramhunter9
use a big ol hammer and drink some beer it will come off one wat or the other
Old May 4, 2009 | 08:09 PM
Off_Road_Teacher
I was able to get my fan off with a homemade spanner wrench and a pipe wrench.
Old May 4, 2009 | 08:10 PM
nim81's Avatar
nim81
autozone also rents a tool for fan clutch removal.
Old May 4, 2009 | 08:17 PM
Off_Road_Teacher
Personally, I think he is turning it the wrong way unless the 4.7 is threaded differently than the hemi.
Old May 4, 2009 | 08:22 PM
MikeHTally's Avatar
MikeHTally
I used a spanner and a big crescent wrench. Yep, sounds like you're turning it the wrong way. From the passenger side, wrench up, pull toward you.
Old May 4, 2009 | 08:23 PM
nim81's Avatar
nim81
if you have the hemi, and i have the 5.9, and they are both regular threads, i agree with you 100%.
