oil change
Old May 4, 2009 | 09:18 PM
bloodySUNDAY134's Avatar
bloodySUNDAY134
Default oil change
ok, the "change oil" message that reads out by the odometer has been flashing and chiming since my last oil change and i still have over 1,000 miles to go until my next one. it has done this before and the dealer cleared it by turning the ignition to the on position and then depressing the brake pedal twice to clear it. i've tried this and it has not cleared the message. when the dealer did it, i did not have my tuner uploaded on the rig and now that i do have it uploaded, i cannot get the message to clear. would my tuner have anything to do with this?
Old May 4, 2009 | 09:55 PM
chambers's Avatar
chambers
Try disconnecting the negative battery cable for a few minutes.
Old May 4, 2009 | 09:57 PM
justanothermoparman's Avatar
justanothermoparman
I think you actualy need to turn the ignition on then depress the gas peddal twice then on the second time you hold it for 10 secs. This is how it's done on my wifes nitro.,
Old May 4, 2009 | 10:21 PM
Dodgeboy77's Avatar
Dodgeboy77
i thought it was 3 times
Old May 4, 2009 | 11:12 PM
seawind3000's Avatar
seawind3000
It is 3 times.... quickly, after all the lights go off ( or stay on) LOL
Old May 5, 2009 | 03:14 AM
abarmby's Avatar
abarmby
Wow .................pressing the brake pedal like this is a bit like Michael Flatley doin' the "river dance" ha ha ha.
Al.
Old May 5, 2009 | 12:44 PM
Redone4x4's Avatar
Redone4x4
Al.
lmao...riverdance haha.
Old May 5, 2009 | 12:49 PM
Cheeech's Avatar
Cheeech
turn key to acc position and wait for the bell to stop dinging. Then press the gas pedal to the floor 3 times and then start the truck. Your done.
However, if the ecu shows an oil change is needed. More than likely you have been hard or done city driving and your oil is in need of a change. I'm sure that 1kmi won't hurt anything. Just check the level.
Old May 5, 2009 | 02:00 PM
bloodySUNDAY134
thanks cheeech, that worked nicely. u da man.
Old May 5, 2009 | 03:35 PM
Cheeech's Avatar
Cheeech
I know.....aaahahahahaha j/k
Glad you fingered it out....
