cranking the t-bars
Old May 12, 2009 | 09:57 AM
dutter's Avatar
dutter
Default cranking the t-bars
dose anyone have a link on how to crank the t-bars? i did a search and came up short
Old May 12, 2009 | 11:12 AM
dutter's Avatar
dutter
found some info googling, it brought me to another forum. seems simple enough. i never had a truck with torsion bars so this is new to me.
Old May 12, 2009 | 11:54 AM
05DodgeRamHemi's Avatar
05DodgeRamHemi
Can you level the truck with adjusting the torsion bars? Does it cause any wear on front end components leveling the truck that way?
Old May 12, 2009 | 12:14 PM
ramhunter9's Avatar
ramhunter9
fellas ... yes if you have a IFS front end with t-bars you can crank them to level the front of the truck, its prety simple just look at the crossmember under the rig you will see two keys with two bolts in them ..those are your bolts you will be crankin on just rember to do each side equal amounts of turns. it will be easier to turn them with the front end on a jack to releave preasure. now after you get done crankin them and gettin the level you want (2'' the max) take your truck in for a alinment!!!! then start looking for longer front shocks 2'' bigger than stock.
and this wont cause anymore stress on the ball joints ect than normal because you are not lifting it upi that much.
RH
Old May 12, 2009 | 12:37 PM
dutter's Avatar
dutter
RH
thanks ramhunter, i was thinking there was a lot more involved to it. all my other 4x4's had a front axle.
Old May 13, 2009 | 11:48 AM
dutter's Avatar
dutter
cranked em' after work. it was so easy i feel like a tool for asking how to do it. next time i'll look under the truck first. i ened up with 8 turns to get the front close to the rear, it still sits around 1/2-3/4" lower. tires and alignment tomarrow.
one question though, is it ok to go past 8 turns? there is still some thread left on the adjustment bolts.
Old May 13, 2009 | 12:21 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
wow, 8 turns?! most I'd heard of before was 5-5.5 turns. I only went 2-3 to avoid stiffening the ride.
well, if you still got thread left, you still got some room. crank em up some more if you feel like it. maybe the previous owner cranked them the other way?
Old May 13, 2009 | 12:46 PM
dutter's Avatar
dutter
thats what i was thinking because the adjustment bolt was allmoust fully backed out & the front end felt a little soft allmost "car like". when i measured the rear is sitting at 40" (ground to wheelwell), the front was only sitting at 36 1/2", thats a 3 1/2" difference. now there is only 3/4" difference & there is still around 5/8-3/4" left on the adjustment bolt threads.
Old May 13, 2009 | 01:46 PM
ramhunter9's Avatar
ramhunter9
lets see a pic already!!!!!
Old May 13, 2009 | 02:02 PM
Ridinhigh's Avatar
Ridinhigh
man I would love to crank mine but I am waiting until I can buy the longer shocks and do it all at the same time
