Where did the 100hp come from in 08 4.7?
Old May 16, 2009 | 02:07 PM
Bigc9164's Avatar
Bigc9164
Default Where did the 100hp come from in 08 4.7?
where did the extra 100hp come from the the 2008 4.7 and can i do it to my 2007 4.7. i think they are new cams right. but i didnt think you could get 100hp from just new cams. and where can i get them?
Old May 16, 2009 | 02:46 PM
fourseven's Avatar
fourseven
I don't know the specifics, but I think it's an entirely new engine design, consisting of much more than just new cams giving the boost in power.
Old May 16, 2009 | 02:54 PM
Bigc9164's Avatar
Bigc9164
well i am looking to get 300hp and not just a small 220 hp from my 4.7 now. and i would like to know what i can do to get the extra power that is not programmers or cai or exhaust. and i dont want to spend a ton of money either. i was thinking H.O. cams but im not sure yet though. how much more power am i looking at with that?
Old May 16, 2009 | 03:18 PM
WeightLifter500's Avatar
WeightLifter500
They put larger heads on it, better cam, advanced timing, and a better breathing motor. Ported heads is $2000, the H/O cams would be $300; however, I would go with 206 cams, the timing can easily be achieved through a SC tuner, and a aftermarket CAI w/ better headers would take care of the breathing part. All together you would end up over 300hp and with well more that 400tq. That is what I am working on right now on my 05.
Old May 16, 2009 | 03:27 PM
lxman1's Avatar
lxman1
Site Moderator
Redesigned heads with dual spark plugs and more compression.
Old May 16, 2009 | 03:43 PM
dirtydog's Avatar
dirtydog
Moderate User
I hope you figure those numbers to be flywheel and not rwhp, because that's what it will be. Personally, I would drop in a used 5.7L. You can get a low mileage used one off ebay shipped to your door for under $3k
Old May 16, 2009 | 03:55 PM
Bigc9164's Avatar
Bigc9164
ya but more hp out of a smaller engine is more impressive we dont NEED a hemi. ha.
Old May 16, 2009 | 04:20 PM
dirtydog's Avatar
dirtydog
Moderate User
Old saying...No replacement for displacement when it comes to N/A motors.
I'd rather swap a 5.7L or add a s/c'er to your 4.7L versus install new heads, cams and a custom dyno tune to get things squared away. That's the expensive route and more time consuming. You'd wanna remove the engine anyways to do all that work. It would be silly to do it in the truck.
Old May 16, 2009 | 04:44 PM
RagingSamster's Avatar
RagingSamster
Are they made for the 4.7?
Old May 16, 2009 | 05:49 PM
dirtydog's Avatar
dirtydog
Moderate User
The best money can buy------->http://www.kennebell.net/supercharge.../47ramsohc.htm Not sure when it will be available? The 5.7L are finally releasing in June.
OR http://www.paxtonauto.com/pdf/manuals/4809641.pdf
