Rear power Slider
Old May 24, 2009 | 12:25 AM
MexiRam's Avatar
MexiRam
Default Rear power Slider
Has anyone here installed one of these power sliders. Was wondering if its an easy install?
http://truckininstyle.com/latemodelsliders.htm
Old May 24, 2009 | 01:37 AM
lxman1's Avatar
lxman1
Site Moderator
Looks to be the same as installing a regular window. Mine has a factory power slider, so I don't know any install details.
Old May 24, 2009 | 02:05 AM
all of 75's Avatar
all of 75
Looks good, but what would be really cool (for some occasions) is if the whole window would slide down into the body.
I hate to say it but, like the toyotas.
Old May 24, 2009 | 02:10 AM
MexiRam's Avatar
MexiRam
actually is only the center middle window that slides to the driverside with an electric switch. I had one on a 96 ram but had it put on by someone charged me 300 dollars I cant find the one that slides down into the body that would btter. Any ideas wher to get those?
Old May 24, 2009 | 02:25 AM
AF_HEMI's Avatar
AF_HEMI
wow...is it really worth $400 for your rear window to slide?
Old May 24, 2009 | 03:04 AM
MexiRam's Avatar
MexiRam
yeah kind pricy. i dont have a rear slider at all is one single piece .
Old May 24, 2009 | 03:44 AM
lxman1's Avatar
lxman1
Site Moderator
Ford also has the slide down rear window in the Explorer Sport-Trac.
I'm guessing there isn't enough room between the inner and outer rear walls of the cab to install such a unit.
I'm guessing the hardest part would be running the wires from the rear to the dash area and mounting a switch. I'm sure a glass shop wouldn't charge much to swap out the window part if you can wire it yourself. They are quite handy in a QuadCab, since you can't reach the rear window from the front seat.
Old May 24, 2009 | 09:44 AM
HEMISith's Avatar
HEMISith
Unless you have monkey arms like me!
Old May 24, 2009 | 10:41 AM
Mystro's Avatar
Mystro
My truck came with a power slide and I cant believe how much I use it. All my Rams before had a non-power rear glass and I would occasionally use it for hauling 16' trim pieces. I use the power rear slide all the time for ventilation.
Old May 24, 2009 | 12:03 PM
nim81's Avatar
nim81
i test drove a plethera of trucks before i got mine and all the ones with power sliders didnt work, and the ones that did work were shotty at best. the salesmen were all retarded about them like it was the only reason to buy the truck.
i have a non-power slider and i dont think ive opened it up once.
