ABS and BRAKE light and cruise issue....
Old May 30, 2009 | 07:01 PM
Romeosoldier03's Avatar
Romeosoldier03
Default ABS and BRAKE light and cruise issue....
so...today i started my truck up and my abs and brake lights on dash came on....truck ran fine and braked fine...got on the hwy still good...then set the cruise and the cruise wouldn't even come on....WTF???? then to top it off sumthin' hit my dam windshield and cracked it.......geez wat a bad day. anyone know anything bout the other abs and brake light issue?
Old May 30, 2009 | 07:14 PM
Romeosoldier03
Old May 30, 2009 | 08:05 PM
Ilovemytruck's Avatar
Ilovemytruck
well, I had the same issue, does your speedo pulse when in drive but stopped at a light?
Wheel speed sensor on top of the differential is usually the culprit. Its about 60.00 at the dealer and they want 250.00 to install it. It took me 10 minutes to change, not even... Also if you have water in the abs control module, it will throw those same light on.
Old May 30, 2009 | 09:46 PM
Romeosoldier03
anyone else know why it would set all 3 symtoms??????
Old May 31, 2009 | 12:05 AM
Ilovemytruck
look in the haynes manual then you can thank me later lol
Old May 31, 2009 | 02:35 AM
Fris's Avatar
Fris
If your ABS or brake light is on, the cruise control will NOT function. This is a safety thing that is built into the truck's system. The ABS/brake light can come on for something as simple as low brake fluid. Have you checked that?
If you do have low brake fluid, you can either be running with almost worn brake pads OR you have a leak somewhere. Hopefully not a leak as that can be very dangerous.
Old May 31, 2009 | 04:29 PM
spankyj55's Avatar
spankyj55
WTF!!! abs LIGHT COMES ON, HEADLIGHTS COME ON, GAUGES FLAT LINED AND ALL THE IDIOT LIGHTS COME ON. i PULLED UP 3 CODES; u0101, U0155. TRUCK RUNS GOOD AND BRAKES ARE WORKING. What's going on?
Old Jun 11, 2009 | 05:19 PM
1972Ghia's Avatar
1972Ghia
I am experiencing a similar porblem in my 04, except my cruise control works, but the engine acts like it is misfiring when on cruise. I read in these forums that there should be three sensors, one on the rear differential, and one on each front wheel. I found and replaced the sensor on the rear and that didn't work, so I peeked under the front. I only found one sensor in the front (on the driver's side). Anyone know if this is correct? Should I have two up front?
Old Jun 11, 2009 | 11:10 PM
hemidel's Avatar
hemidel
To help you with your problem, i just delt with this last week. Same thing happen to me. Abs and brake light came on, and my speedometer was jumping around. It turned out to be the rear abs speed sensor as someone mentioned earlier. It sits on the top of the rear differential. Hope this helps....
Old Jun 17, 2009 | 03:05 PM
thekidnotakid's Avatar
thekidnotakid
I recently changed out my front axel seals. To the best of my recallection,there is a speed sensor at each front wheel.
