combo oil/trans temp gage
Old May 31, 2009 | 11:05 PM
ctrhenry's Avatar
ctrhenry
Default combo oil/trans temp gage
i want to use a single gage pillar to keep the handle and use a single back lit temp gage and have it hoked through a switch to alternate between the oil and trans temperature anyone done this??
oh, my names chris i have a 2008 QC 4.7 in pantydropper blue, live north of nashville tennessee and enjoy long walks on the beach
Old May 31, 2009 | 11:06 PM
ctrhenry's Avatar
ctrhenry
i found both the tranny tem gauge install threads, the diy and the one with 2 sensors 9 where i got the idea
Old May 31, 2009 | 11:09 PM
SilverBullet08's Avatar
SilverBullet08
i dont think there is a gauge that reads oil and trans temp.
Old Jun 1, 2009 | 12:18 AM
Rojhan's Avatar
Rojhan
Fluid temperature is fluid temperature, whether it is water, oil, or transmission fluid. As long as the sensor is matched to the gauge, you can run multiple sensors to the same gauge and use a switch to select the one you want.
My transmission gauge reads 100-280F, and normal temperature is 140 (city) to 190 (towing a grade). I think engine oil should be in the 200-250F range so the gauge should be fine for oil as well.
Old Jun 1, 2009 | 12:34 AM
Redone4x4's Avatar
Redone4x4
i think its a pretty good idea. i dont want to lose the handle for another gauge either, so dont blame you there. try it and let us know! sounds like maybe just a switch, relay and a few extra wires would do it.....
Old Jun 1, 2009 | 12:44 AM
Rojhan's Avatar
Rojhan
For the current involved, no relay needed. An SPDT (single-pole, double throw) slide switch would work fine for two sensors. You could even get a multi-position slide switch or a rotary switch and have a combination of trans temp send/return, oil send/return, coolant temp, etc. Go nuts.
Old Jun 1, 2009 | 01:03 AM
AF_HEMI's Avatar
AF_HEMI
Hmm that sounds like an AWESOME idea!! I'm gonna go ahead and add this to the To-Do list
Old Jun 1, 2009 | 06:19 AM
Lifted4x4Astro's Avatar
Lifted4x4Astro
I already did this...see this thread: https://dodgeforum.com/forum/3rd-gen...e-install.html
I am monitoring 2 different transmission temps but it still applies. You would just need to decide where to place the engine oil sensor.
Old Jun 1, 2009 | 12:56 PM
emcanurse's Avatar
emcanurse
Default gauges
You can try these gauges. The are about 300 american. But are excellent gauges. We used one in our rally car.
http://www.spatechnique.com/product_...page.cfm?cat=2
Stuart
Old Jun 2, 2009 | 12:47 AM
ctrhenry's Avatar
ctrhenry
not going to use a switch, i will wire up a little circuit to alternate at preset intervals.
going to start hunting gauges now, i think i found the pillar on ebay
