3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
The emblem is kind of cool....the chrome ram part kind of snaps on to the black part which is stuck on there with double-sided tape. I just used a small flathead screwdriver to pry it off carefully. The chrome grill is easy but with a painted one, you would have to be very careful! LOL
so you took it off like you did with your badges, then you can pop it off with a screw driver? I would like to get rid of the ram head and put something else on there.
The grill emblem comes in two parts - the black background and the chrome Ram emblem part. The black plastic background part is stuck on like our badges but has two little nipples sticking through the grill. (huhuhuh....he said 'nipples')
The chrome Ram emblem part snaps around and into the black part. The bottom has a couple of tabs that hook on and at the top there is a part that snaps in. Once you get it apart you will see it. You could probably use fishing line to get it fairly loose without having to use a screwdriver. Your grill is painted as well so fishing line might be the best option.
