Running Hot!!!!!!!!
Old Jun 13, 2009 | 07:53 AM
R.R.'s Avatar
R.R.
Default Running Hot!!!!!!!!
My Son has a 2005 dodge pickup and on occasion it will tun hot. It is not a constant thing. It will go up halve way between normal operating temperature and hot, for a few miles then come back down to normal. Anyone have any thoughts on this!!!!!!!!!!
Old Jun 13, 2009 | 08:00 AM
kev2's Avatar
kev2
first thoughts
easy things first-
coolant level, no leaks?
nothing blocking air flow?
fans operating?
no check eng light? free code ck at some parts stores ie auto zone-
vehicle is stock?
then if nothing applies:
I would then replace thermostat- recomend a OEM correct temp!
Old Jun 13, 2009 | 08:18 AM
MikeHTally's Avatar
MikeHTally
Does it do this on the highway or in city traffic? If it does this on the highway, the t-stat is intermittently sticking closed. I had the same problem on my '03. If it does this in traffice, it could also be an intermittent fan clutch. Maybe time for an e-fan.
Old Jun 13, 2009 | 08:43 AM
Gone Fishin's Avatar
Gone Fishin
Drain the old coolant (its time anyway), run radiator flush through it to clean up system, rinse out thoughly, replace the stat, refill with pre-mixed coolant. Make sure you have the heater on too while running flush through cooling system, and while rinsing out flush agent.
Old Jun 13, 2009 | 08:48 AM
BEAR's Avatar
BEAR
sounds to me like a air pocket in the system.
Old Jun 13, 2009 | 11:08 AM
HammerZ71's Avatar
HammerZ71
Yep, I'd burp the system first, then look at the thermostat...
Old Jun 13, 2009 | 11:12 AM
casper3380's Avatar
casper3380
check the radiator cap as well, if its not holding proper pressure it will cause it to overheat under load. A flush is recommended as well.
Old Jun 13, 2009 | 12:25 PM
dirtydog's Avatar
dirtydog
Moderate User
def an air bubble in there.
Also, I used Roayal Purple's "Purple Ice" coolant additive and it works awesome. i first used it on my Mustang and noticed much cooler temps. Consistent temps. Dropped 15-20* hot. It runs $15 per bottle and all you need is one. Dropped theneedle on my truck guage about 1/8th way towards cold.
Old Jun 13, 2009 | 03:58 PM
BEAR's Avatar
BEAR
I think HAMMER has a DIY in the FAQ section on burping the system. And like previously said, check that radiator cap or just replace it, cheap insurance.
Old Jun 13, 2009 | 07:25 PM
Ilovemytruck's Avatar
Ilovemytruck
When burping the system, do you wait untill the temp guage reaches 1/2 way mark untill you turn it off or should it burp before then? I tried the parking on the hill and turning the heater on full but it didnt work. Also, can you buy that royal purple at autozone or advanced auto?
