Help- 04 hemi won't start when warm
Old Aug 3, 2010 | 12:47 AM
brettj2408's Avatar
brettj2408
Originally Posted by abarmby
Try using fuel and not flue...........to make it run
lol
Old Aug 3, 2010 | 02:44 PM
Sclayton's Avatar
Sclayton
I have the same issue on my 05 hemi sport... I have so far traced it down to being a leaky injector. I have done everything everyone else has tried.. Same exact starting issue. I have yet to pull the fuel rail/injectors and see though..
Have a look at your oil.. see if it is getting fuel in it.. mine has lots.. that whay cold starts are fine.. The rail has depressurized and washed down the cyl walls. On a warm start it seams to be flooded. you will also see a puff of smoke when warm starts accour with acc to the floor because of the added fuel..
I would love to know anyone that has ever fixed this issue... I have herd of it many times....
Old Oct 17, 2013 | 11:45 AM
Jibarra77's Avatar
Jibarra77
Ok guys here is your problem you have a bad injector or more than one. I had the same problem with my truck for long time. And no body knows. Until somebody told m to check my injectors. And sure that was. I had one bad injector. I replaced and tha fix my problem. Now I start my truck with no problem.
Old Oct 17, 2013 | 09:19 PM
rought's Avatar
rought
I have had starters that would loose cranking power when hot. still worked just not as strong..
Old Oct 18, 2013 | 06:48 AM
Jibarra77's Avatar
Jibarra77
Ok guys. You have a bad injector. Is why your truck won't start unless you press tje gas when is warm. Pull your injector rail and with the injectors on. Put your key to on position not starting the truck. Just for tje pump to put pressure in it. And see wich one leaks. You have to put paper under neath the injectors. I find out like that on my truck. And that was only one bad. I replaced and that fix my problem. Thanks
Old Feb 26, 2019 | 07:23 AM
Debbie Hamm's Avatar
Debbie Hamm
Default 04 1500 ram hemi.
I'm having the same issue I've had in to multiple shops and no one can figure it out. Throdle body is clean, fuel pressure good. The last shop thinks its getting to much fuel but doesnt know why.
Old Feb 26, 2019 | 09:19 AM
Next time it doesn't want to start, stomp the gas pedal to the floor, and hold it there. Crank the engine. Does it start?
