Doing first oil change....questions...
Old Jun 15, 2009 | 12:20 AM
bert6573's Avatar
bert6573
Exclamation Doing first oil change....questions...
So, it's about time to do an oil change on the Ram.....
uhm, I will do the oil change myself, and well this will be the first time I've ever changed oil on a vehicle.
I will change to synthetic oil, Mobil 1
but how many quarts do I need in my truck....2007 Ram 1500 4.7 flex fuel......
and what kind of filter should i use???????..............
recommendations will help...
Old Jun 15, 2009 | 12:29 AM
bert6573's Avatar
bert6573
Talking
also, what should i use in the gas tank....uhm, what is it called...you know to boost your mpg's..........uhm, a gas treatment???? which one should i use......
Old Jun 15, 2009 | 01:15 AM
irelandshemi's Avatar
irelandshemi
forgot how much oil i use but i wouldnt bother with the mpg booster they dont work
Old Jun 15, 2009 | 01:21 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
To boost your mpg do the drive slower mod....I think it's posted in the DIY section
Old Jun 15, 2009 | 02:18 AM
bert6573's Avatar
bert6573
good one....++1...
Old Jun 15, 2009 | 03:21 AM
Joel_MD's Avatar
Joel_MD
According to the Amsoil website, your engine takes 5.9 quarts of oil.
Any high quality oil filter will work fine. Personally I would suggest the Amsoil Ea filter for your Ram, which is part number EAO42.
You could also go with a K&N HP-2004. It's a good filter and comes with a nut welded on the canister to help you get it off.
Here are a couple of oil filter hints I learned here on the Cummins forum:
When you remove your old filter, first bust it loose with a filter wrench or whatever you use. Then take a zip lock bag (quart size should work on yours, gallon size is best on the Cummins filter) and slip it over the filter before you continue spinning it off. That way all the oil that comes out stays in the bag.
When you install a new oil filter, use a dab of bearing grease on the gasket instead of motor oil or WD-40. It makes the filter slightly easier to remove the next time you change oil.
Old Jun 15, 2009 | 07:02 AM
MikeHTally's Avatar
MikeHTally
All good. You might want to try a gallon-size plastic bottle (windshield washer or even an old 5 gal. oil jug) instead of the plastic bag. That has worked better for me.
Old Jun 15, 2009 | 07:20 AM
HammerZ71's Avatar
HammerZ71
six quarts.
Mobil, Wix or Purolator filters seem to be about the best out there.
As far as a gas treatment/additive, I've always used a good quality fuel injector cleaner in the tank every 3k miles or so, something along the lines of STP or the like, although many people swear by Seafoam. I've used it in small engines (lawn mower, weed whackers, etc.) with fantastic results. I should probably give it a try in the truck or jeep...
Old Jun 15, 2009 | 07:35 AM
BEAR's Avatar
BEAR
Marvel Mystery Oil Is a good fuel additive for cleaning the fuel system.
Old Jun 15, 2009 | 07:38 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I've had good results with the Lucas fuel system treatment in the past.
