Transmission wierdness.
Old Jun 15, 2009 | 06:19 PM
Bluesmanjesse's Avatar
Bluesmanjesse
Default Transmission wierdness.
I am new to the Dodge truck ownership expierience and I may be worried for nothing but I have to ask.
Here's the deal,sometimes when I get in my truck and start it up after work or something and I put it in gear it will not move for maybe a second then it seems like the trans builds pressure and goes,is this common with these trucks or is this a sign of impending problems?
The truck is a 2006 hemi 1500. I searched the forums and I couldn't find this specific trans issue anywhere.
Old Jun 15, 2009 | 06:53 PM
Wanderer's Avatar
Wanderer
The frist item I would try is a fluid and filter(2) change. The recomended service interval is 30,000 mile. At that time, any adjustments can be made. A second or two delay on a cold engine is not unusual.
Good luck with the new ride.
Old Jun 15, 2009 | 07:29 PM
MikeHTally's Avatar
MikeHTally
My Gen II did that, but it had a known small leak.
My Gen III doesn't delay after sitting a week or more. Check the fluid level first. Yep, it's time for a drop 'n' drain and filters.
Old Jun 15, 2009 | 08:06 PM
Bluesmanjesse
I've only owned the truck about 2-3 weeks now and it has 48,000 miles on it,I don't know if the previous owner did anything with it or not as far as fluid/filter changes. I did look at the fluid when I was looking to buy the truck and it looked nice and pink on the dipstick. I had an old transmission shop guy tell me to apply a thin layer of vasoline to the trans pan gasket whenever doing a change and this would prevent the gasket from leaking. DO you guys think that is a good or bad idea? I never tried it but the old guy seemed to know what he was talking about.
Old Jun 15, 2009 | 10:28 PM
RedTruck-VA's Avatar
RedTruck-VA
The vasoline trick only keeps the gasket from sticking to the valve body and allows you to reuse the gasket.
Old Jun 16, 2009 | 02:20 AM
Bluesmanjesse
Just talked to the local advance auto parts and apparently my truck has both a screw on filter and a normal style filter,does that sound right to you guys?
Old Jun 16, 2009 | 02:39 AM
abarmby's Avatar
abarmby
Yes about the filters.
One is a rather large pancake filter and the other, a small spin on cartrdge type.
Make SURE, that when you order up your filters, you get the correct 4wd pancake filter. There is a difference between the 2wd and the 4wd vehicles in that the pickup is longer on the 4wd.
Hope this helps?
Al.
Old Jun 16, 2009 | 02:45 AM
Bluesmanjesse
Hope this helps?
Al.
Ya, the computer at advance showed one filter for 2wd one for 4wd and the spin on. Thats how I came to know I needed 2 filters,I'll probably pick them up tomorrow. Thanks for the confirmation man. This site rocks!
Old Jun 16, 2009 | 11:19 PM
dasman7580's Avatar
dasman7580
I have been experiencing the same problem with my 2005 4x4 Hemi. I went to change the tranny filters (primary and cooler return) and fluid, but was given the wrong primary filter. Luckily I didn't find this out until I had the RTV sealant on the pan ready to put everything back together. After a flying trip to Autozone, accompanied by a few choice words, I returned it along with all the fluid that dripped on it while trying to install it. They apparently did not have the right one so I went next door to O'Rielly's and found the one I needed. A few days later I noticed that after sitting all night the transmission wouldn't engage unless I let the truck warm up for about 10 seconds. This has been going on for about a month until I found this TSB "technical service bulletin" posted on a dodge website (http://dodgeram.info/tsb/2006/21-007-06.htm). Not only did Autozone give me the wrong primary filter, but the wrong cooler return filter as well. I picked up the one listed on the tsb today and hopefully that will fix the problem. I've decided I'll sell the truck before I change the tranny fluid and filters ever again!!!!!! Hope this helps???
Old Jun 18, 2009 | 03:05 AM
Bluesmanjesse
Man that sounds like my kinda luck! We must be brothers from different mothers,lol I am going to make sure I get the right one.
