Spark plug problems?
Old Jun 23, 2009 | 01:04 AM
  #41
bigmiah22's Avatar
bigmiah22
Originally Posted by Bluesmanjesse
Post them on craigslist maybe you can at least get back half your $
Not a bad idea...thanks
Old Jun 23, 2009 | 10:38 PM
  #42
RAMJEN's Avatar
RAMJEN
I am at 34K miles on my 2007 and I am going to pay the dealer 180 bucks to change them all. I am going to assume (will check) they are going to use MOPAR plugs and that they are gapped like they are supposed too. How hard is it to change 16 plugs.....I am not a mechanic. I have changed plugs many times before though. What are the best plugs keeping in mind I like to keep it all factory for now.
Old Jun 24, 2009 | 03:24 AM
  #43
bigmiah22's Avatar
bigmiah22
Its really not that hard. NOT worth 180 bucks thats for damn sure...the passenger side is easy just remove your intake and all 8 plugs are right there in front of you, then on the driver side, the first 4 plugs are easy to get to, the back 4 are the hardest but with a little patients and the right socket extensions you'll have little to no problems...I've heard an easy way to do the driver side is to just remove your tire and the wheel well cover on the driver side and the plugs are right there in your face, so thats something to think about too..
Old Jun 24, 2009 | 03:57 PM
  #44
LinerJoe's Avatar
LinerJoe
I changed the plugs in my '07 hemi last week. I am not very mechanically inclined, but I was able to do it. However, it did take a long time. I broke it up into 2 nights. I would say it took me about 4.5 hours total. I also cleaned the throttle body (which was very dirty) while I was at it.
As others have said, the passenger side was quite a bit easier than the driver's side. I did not remove the tire, so I had to go from the top... the brake booster is right in the way. You will definitely need a swivel (knuckle) or 2.
I checked the gap on all of the Champion plugs (and they were all fine, I didn't adjust any of them) before I put them in. I also used a torque wrench to make sure they were in correctly.
I must say that it drives better than it did before the change! I'm guessing that the biggest impact was the cleaning of the throttle body. It seems much smoother on acceleration. The plugs that I removed all looked pretty good, but a few were starting to get a little dark.
I had 30,200 on it when I changed them.
joe
Old Jun 27, 2009 | 03:22 AM
  #45
bigmiah22's Avatar
bigmiah22
Sooooo i finally got around to changing the plugs in my truck again. the 3rd time now for me....took out the platinums and put in the copper champions and replaced the wires and now my truck is running perfect! just wanted to say thanks for all the help guys!
Old Jun 27, 2009 | 09:41 AM
  #46
LinerJoe's Avatar
LinerJoe
I'm glad to hear that it's running better now!
joe
Old Jun 27, 2009 | 10:02 AM
  #47
BEAR's Avatar
BEAR
It sure ain't worth 180.00, I mean the back ones on the drivers side are a pain but like its been said with extensions, a swivel or two and some patience you shouldn't have too much trouble. As far as the best plugs, Champion is what the factory puts in so thats always my first choice. And BIG, Good deal man! I'm glad to hear your problem is solved. I know it took allot of work but I'm sure it was a lesson learned.
Old Jun 27, 2009 | 03:15 PM
  #48
bigmiah22's Avatar
bigmiah22
A huge lesson learned for me on the other half, i'm a pro at doing my plugs now, and on top of that, murrays took back the platinums and refunded my for them so i was extremely happy to save 49.75 there...
Also, if youre planning on doing your plugs, i found out that taking off the hemi hat thats before your throttle body makes it a lot easier to reach the back 4 on the driver side...just a little extra info
Old Jun 27, 2009 | 03:21 PM
  #49
BEAR's Avatar
BEAR
You should have timed yourself the last time and seen if you can beat Ramhunter1!!
Old Jun 28, 2009 | 04:34 PM
  #50
gellin9o9's Avatar
gellin9o9
Default spark plugs
im doing y own plug swap aswell and i seen that you guys are using the copper plugs i was told the best to use were the iriduim plugs especially for the waste plug anyone using these ones cause allthese plugs just sey me back a buck twenty
