Damn Thieves! Need suggestions for aftermakerket alarm systems
that is if they don't go directly into cardiac arrest from the train horn going off right next to their head haha
Train horns need lots of air volume. means, an external compressor is needed. Those little red plastic one's that AZ sells are junk. A compressor needs lots of power to run, so while your alarm is going off, the air hoen compressors would probably kill your battery after just 1 minute, but a dead battery is better than a loss of equipment.
You could always just shave the door handles and locks and put some of that window security laminate that you can buy for you house windows on all the windows on the truck so they wont be able to break in. You can beat the hell out of that stuff with a sledge and not break through it.
Just dont drive into any rivers or lakes where you may need to break the glass in order to get out of the truck...
my train horns have a 5 gal tank which stays filled so when I use them I get about 5 full pressure blasts about 5 normal blasts adn about another 10 weak blast which are still louder than factory horn....or I get about 1 15 second solid blast
I have an autopage 757lcd, its two way, and eventually you can add the optional c3 module which makes lojack look pathetic. Your phone will be connected with you truck at all times as long as you have signal and you can set up a perimeter so that if your truck leaves that perimeter it will send a signal to your phone if they did manage to override the killswitch, and stop the alarm from going off in the first place, it also makes it gps trackable. I would seriously look into that alarm, its a really good one, its the one that i have and am getting switched from my old pickup into my new one because I am so happy with it. It also has the optional module to be able to roll your windows up and down and autostart and all kinds of cool little addons. Hope that helps!! It cost me $450 to get mine and have it installed btw, without the remote start
buy yourself a taser and have some fun with whoever wants to take your s***.
http://www.defenseproducts101.com/st...ary_page2.html
I would buy one here to keep in home but I'm sure the parents would be THRILLED that I bought one.
GOTTA be careful with those. Some states those are illegal and even if they aren't, most of those that are sold have enough voltage to kill someone. Mame or even kill someone with a tazer and you'll be going away for a looooong time. Guaranteed. Just a heads up on that. Even with pepper spray, the higher concentrated doses can actually blind people. regardless of what they did to harm you or your property, it's illegal to mame or brutally beat anyone.
If i had it my way, an eye for an eye sorta thing. Lot less crime would occur! that's what they do on the islands and foreign countries. Their crime rates are lower than ours! Go figure.
unlikely to cause death. There have many tests done by the taser and independent industries. There have been no deaths reported from taser usage considering the amount of criminals who have been tased and even police recruits willing to get tased in the academy. Taser International and LE have done over a million taser tests without causing one death. A Taser also has no affect on the heart so that's out of the question. Maybe the person will lunge at you to try to harm you if you catch him/her trying to break into your car, then you can do what you want to a certain extent and get away with it
Sorry, getting a bit off topic here
