Hey guys, Couple of things if you don't mind
#21
I also believe there's a good chance you've got an air pocket in there, possibly amongst other issues. Did you perform the bleeding procedure after replacing the stat? How much coolant are you dumping in every day? is it just a little here and there, or are you laying in quarts at a time?
As far as replacing a head gasket in your friends back yard... I'd never disrespect the abilities of anyone I've never met or seen work. But replacing a head gasket is a BIG job, and your truck is quite a bit different than a 68 or 69 Camaro. If that's the road you get led down make sure you know what you're getting into, the outcome could be a lot worse if it's not done right.
#22
I just meant he's good with automotive stuff in general. I'm about %90 sure he can do it. He used to be a mechanic somewhere noteworthy lol. I don't know where exactly, I was like 10 whenever I found out about what his dad did and I didn't really care...I mean, I was 10. haha.
Sorry if this isn't the most coherent post, I just got home from last night. That being said, it's nap time. I'll catch up here later
