HID Vendor Group Buy
Color temperature are offered in:
3000K (Lumen output - 4000 lm) - Golden yellow
5000K (Lumen output - 3250 lm) - White with yellowish tint
6000K (Lumen output - 3000 lm) - Diamond white
I'd bet if you get their 6ks they start lookin blue
yea, so their colors run a little 'hotter', no big deal. just something to know before you order. I'd still order from these guys if I had anything other than an 02-05 ram, still a good quality kit.
Hi all,
Sorry to have some problems with a couple of you, just want to let everyone know that we only had 3 issues out of over 15 kits I've sold the past month. Alot of things can be affect such as wear on the car itself, the year of the model, or just plain incompatibility with certain cars and it's usually a case by case issue.
Our return policy is that if the kit absolutely does not work in your car, we will definitely give you a full refund. In the past 5-6 years in this business and hundreds of thousands of customers served, we've only had less than 5 customers that had cars that just won't work with our kit and they weren't Dodge.
Again, thanks for all your understanding~
All order placed before 3pm PST yesterday have been shipped, Thank you!
Hi Xfeejayx,
the color can alter a little depending on your headlight cover material (plastic or glass) and thickness and year of wear. The thicker the headlight cover the more white/bluer depending on which color temp you had, and the material greatly affects it too. If the headlight cover is a little dusty it might look more yellow, scratched up overs will also cause the lights reflect in a more scattered beam. Thanks for your understanding~
Michelle
Michelle
