fog light question
Old Mar 22, 2005 | 04:30 AM
usmc hemi's Avatar
usmc hemi
Default fog light question
i have a 2005 hemi slt and i read in a early post that if you look behind the drive side bumper there should be a red caped wire for the fog lights. i looked at mine and i am pre-wired.... i was wondering if i can hook them up myself ( meaning are they already wired to the work with the headlight switch? ) or go to shop to do a in dash switch hook up like my 1998 ram??
[IMG]local://upfiles/13912/E6C642FC80B34FB2AAB7EBFC6F1B238A.jpg[/IMG]
Old Mar 22, 2005 | 04:54 AM
jayskynr's Avatar
jayskynr
Default RE: fog light question
my kit actually had a seperate toggle switch that came with the kit i had to mount near the light ****. everything else was easy to install. the stock **** doesnt have the pull out **** used to turn them on like a truck with them as a stock option (or maybe your kit came with the new ****). just my little imput.
Old Mar 22, 2005 | 05:02 AM
ross944's Avatar
ross944
if the wires are already there then id assume that the lights are hooked up to the switch already. doubt they would go through the trouble of putting them there if they werent hooked up to anything.
Old Mar 22, 2005 | 01:35 PM
shortbus's Avatar
shortbus
thats wierd. My truck doesnt have fog lights, but i have teh pull out headlight **** to operate them with.
Old Mar 22, 2005 | 05:36 PM
usmc hemi's Avatar
usmc hemi
thanks for the info.... i will try it and see what happens
Old Mar 22, 2005 | 05:43 PM
|3|ackAc|D's Avatar
|3|ackAc|D
Speaking of fog lights.. does anybody have some of those after market foglights mounted BEHIND their front grill ?
Old Mar 23, 2005 | 11:00 AM
alienyzf's Avatar
alienyzf
ORIGINAL: usmc hemi
If you order the fog light kit from the dealer it comes with a separate harness (that you have to run all the way into the cab)and a toggle switch(that you have to mount in the dash). If you want to hook it up like factory( ie. using the red cap plug behind the light) you will need the parts mentioned here: https://dodgeforum.com/m_170973/tm.htm
The harness is from the lights to the red capped plug. The switch replaces your factory switch to include a pull **** for the fog lights. There has been a guy on ebay selling the kit for pre-wired trucks if you want to save time and money. Otherwise it is like a $100 extra to buy the parts mentioned plus the fog lights.
Does this make sense now?
Old Mar 23, 2005 | 11:08 AM
alienyzf's Avatar
alienyzf
ORIGINAL: ross944
They are there alright and not hooked up to anything. Even a fuse in the fuse block. It is easier to plug and play options at the factory, than to run a harness on trucks that will have the option.
Old Mar 23, 2005 | 03:06 PM
CousinLk's Avatar
CousinLk
I've tried to find fog lamps for my 1998 Dodge Ram 1500 Quad Cab and I can't find a site or place anyplace....Help!, they mount in the bumper
Old Mar 26, 2005 | 01:37 AM
Parts/Service's Avatar
Parts/Service
All new trucks are factory wired for fog lights, The Mopar install kit comes with a toggle switch and wiring that must be installed. The easiest but more expensive way is to utilized the factory wiring. You have to replace the headlight switch and buy a jumper wire that goes from the drivers side light to the passengers side light.
Jumper wire part # 56045501Ac $ 36.10
Headlight switch Part # 56045537ac $ 51.35
fog light kit Part #82208102
Wiring and switch can be installed in 15 minutes.
Call me at 1-800-663-2522 if you need advice. ( ask for David)i have the parts and can ship UPS.
