Finished my 26gal to 35gal fuel tank swap
Old 08-04-2009, 11:52 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Mine doesnt go over 307 but Im sure thats only because my avg mpg is around 12. So if you take 12*26 you get about 312 and so thats how I think it gets it. But yes DTE does work as the tank gets empty.
  #42
Old 08-04-2009, 04:12 PM
Redone4x4's Avatar
Redone4x4
Redone4x4 is offline
well, 35 x 12 = 420.....So your DTE is still thinking it has a 26 gal tank, but the fuel gauge is reading the 35 gal tank if i recall? Is that correct?
  #43
Old 08-05-2009, 09:24 AM
BigSwede's Avatar
BigSwede
BigSwede is offline
I'm marking this thread so I can see the pics once I get home. While it would be a pain to fill up, you aren't paying for any more gas than you would if you had to fill up your tank for the same number of miles.
Now I just need to find a tank......
  #44
Old 08-05-2009, 01:57 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
that is correct sir.
  #45
Old 08-22-2009, 03:00 AM
chris31101's Avatar
chris31101
chris31101 is offline
I'll definitely be doing this. This will help a lot when I drive the ALCAN - had enough of Alaska time to go back to GA!
  #46
Old 01-25-2015, 02:49 PM
willn69's Avatar
willn69
willn69 is offline
I am doing some research on doing this and I have a couple questions;
1. The quad cab 6.3 bed came with optional 34 gal tank and the reg. cab 8' bed came with optional 35 gal tank. I have a quad 6.3 bed. Would either of these work?
2. I was reading in some other forums that the fuel pump is different for the 26 gal and 35 gal tank. Did you notice a difference?
  #47
Old 01-25-2015, 03:01 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Its been so long I dont remember about the bed but I had no issue using the pump
  #48
Old 01-25-2015, 03:13 PM
willn69's Avatar
willn69
willn69 is offline
Thanx for the quick response. I found both tanks, just want to get the right one for a plug n play. See if I can get some pics and match them up. Of course I want the 35 gal, but will settle for the 34 gal if the other requires mods. Like the PnP you did. Little hassle. Checking out your long tubes in your FYI too. Thanx. I'll let yall know how it goes.
  #49
Old 01-25-2015, 08:57 PM
Will_V2Lab's Avatar
Will_V2Lab
Will_V2Lab is offline
I love my factory 35 gallon tank. Now that prices are low again it only costs me about $75ish to fill up compared to when the prices were high and it cost me about $120.
The extra distance between fill ups is nice. So far the best i've gotten was almost 600 miles to a full tank, but that was pure highway.
Quick Reply: Finished my 26gal to 35gal fuel tank swap
