Torque Wrench for Lugs
Old Jul 21, 2009 | 03:28 PM
reloadin's Avatar
reloadin
Default Torque Wrench for Lugs
Just bout an '05 Ram 1500. Do I need to buy a 90 lb torque wrench to rotate the tires without damaging the rotars?
Old Jul 21, 2009 | 08:20 PM
Laramie1997's Avatar
Laramie1997
It's not so much as worrying about damaging your rotors, as it is stripping a stud out. So in answer to your question, you DO need to get a torque wrench to set it right. IMO a good set of torque wrenches is a must have in every tool chest.
Just an FYI as well, this is a question best suited for the 3rd gen Tech section, found here:
https://dodgeforum.com/forum/3rd-gen-ram-65/
Welcome to the forums, and oh great to have another MO member on here as well.
Old Jul 21, 2009 | 08:50 PM
JDakota92's Avatar
JDakota92
FYI, the torque on your Ram's lug nuts is 135, not 90. Just to let you know.
Old Jul 22, 2009 | 12:33 AM
6 hemi ram's Avatar
6 hemi ram
that seems excessive. i have always gone with 100, especially with the aluminum wheels. out of curiousity, where did you find the torque rating for the the ram J?
Old Jul 22, 2009 | 12:39 AM
jonnymagnum's Avatar
jonnymagnum
I always torque mine to 100. if you go too tight, you can snap a lug off...
Old Jul 22, 2009 | 12:41 AM
Bluesmanjesse's Avatar
Bluesmanjesse
I used a 110 lb torque stick on an impact to put my new aluminum wheels on. I wouldn't go much over 110 ft lbs personally.
Old Jul 22, 2009 | 08:39 AM
RubberFrog's Avatar
RubberFrog
135 is in the book
Old Jul 22, 2009 | 08:57 AM
reloadin's Avatar
reloadin
Thanks everyone! I thought it was 135 (the book says that as well)...for some reason I was told it was 90 and was wondering if anyone had any input. Thanks again!
Old Jul 22, 2009 | 03:41 PM
05hemipwrd's Avatar
05hemipwrd
psh trq wrench, unless its internal trq everything to feel
Old Jul 22, 2009 | 03:52 PM
dirtydog's Avatar
dirtydog
Moderate User
I think Crapsman Torque sticks go up to 15ft/lbs. Plenty for Everything a backyard mechanic would need. Anything more and you'd wanna seek some help. SOme wheel bearings need like 240ish ft/lbs. My Mustang did. I just went on feel..lol
Anyways, on aluminum wheels ALWAYS torque to specs. 135? i just did mine at 110.
My trailer has aluminum wheels that i didn't torque because I was in a rush. i was hearing a clunk when I hit the brakes or going around turns. My wheel was so freakin loose. OMG. Torque ALuminum wheels. Triple check and go back and check in 100miles for any looseness that may have occured.
