Ram 1500 questions
Old Jul 21, 2009 | 08:47 PM
sumncguy's Avatar
sumncguy
http://www.trailerlife.com/ look at the lower right side of the index / home page.
http://www.geocities.com/vidalch_1/t...monstrator.xls. Geocities is being pulled down so if you cant get it there, sent me an email and Ill send the towing demonstrator to you vial email attachment.
Get weighed at the Cat scales to make sure your within your limits.
Old Jul 22, 2009 | 01:06 AM
06 Ram5.7's Avatar
06 Ram5.7
Originally Posted by blackram1500
I was told the most i can put in there are 3:99 gears and if i went higher i would screw up the computer
The highest you can put in is 4.88 if you have a 2WD, or 4.56 for 4WD. And putting in different gears does nothing to the computer, different gears don't affect the speedo or odometer.
I was told by a trans shop that it would cost me around $3200.00 for the front and back.
That is way too high, installation should be around $1000 US, give or take a couple hundred. And while your changing gears, I would suggest either getting a LSD or replacing it, if you have the stock one, with an Auburn or Detroit Truetrac.
Old Jul 22, 2009 | 05:47 AM
SPARTANENGINEER1701's Avatar
SPARTANENGINEER1701
deleted
Old Jul 24, 2009 | 05:54 PM
blackram1500's Avatar
blackram1500
I am new to trucks so what is a LSD? And what do 4:56 gears cost? Cause it looks like I will be coming to the states to get them.
Old Jul 24, 2009 | 06:18 PM
Bluesmanjesse's Avatar
Bluesmanjesse
LSD=Limited Slip Differential
Gear Prices...
http://www.google.com/search?hl=en&q...M+4.56+&aqi=g1
Old Jul 24, 2009 | 06:32 PM
06 Ram5.7's Avatar
06 Ram5.7
Limited Slip Differential. I only say to replace it, since from what I have read on here, the stock LSD is not the best and sometimes can fail, but I have seen a lot of people have no problems with it, but I don’t really know, since my truck came with an open diff. As for the gears, for a complete set with front and rear gears and install kits, about $500-$600.
Old Jul 25, 2009 | 01:01 PM
blackram1500
Default Gears
So , with 3.55 gears = 7600 lbs and with 3.92 gears i can tow 8600 lbs then if I put in say 4.10 or 4.56 then what would be my tow rate. And thanks guys for all your help i am starting to learn alot here.
Old Jul 26, 2009 | 02:03 AM
lxman1's Avatar
lxman1
Site Moderator
I would stay under 9100lbs. The chassis and brakes are not rated for any higher.
Since the speedo reads off of a sensor wheel on the ring gear, gear changes do not effect the reading. Only tire diameter will change the speedo reading, unless the PCM is reprogrammed for the different tire size.
