Lowered Trucks: tech and info....
Old Apr 16, 2010 | 11:35 AM
  #1131
OklaHemi's Avatar
OklaHemi
i like the look look on mine. i have the hemi and like to burn my tires from time to time. the tires make me feel safer. here is a pic
Old Apr 16, 2010 | 11:48 AM
  #1132
Desert_Ram's Avatar
Desert_Ram
Originally Posted by OklaHemi
i have 305/45 and i love them 3/5 drop
what drop do u have okla?
Old Apr 16, 2010 | 12:54 PM
  #1133
rbeard79's Avatar
rbeard79
For the guys with the McGaughy's drops, would you recommend ordering new bump stops from them or just getting some from Auto ZOne or somewhere like that. The kit I got is used and did not come with the bumps. I am gonna get some for the front from AZ, but didn't know about the back ones?? Any help would be great. If anyone has a pic of the bump stops from McGaughy's, I would appreciate being able to see it. Thanks for the help. Hopefully this will go on very soon!!
Old Apr 16, 2010 | 03:25 PM
  #1134
RedTruck-VA's Avatar
RedTruck-VA
Rbeard,
I didn't like the bump buttons that came with my kit. So I ordered a set from Jeg's #19-1314 Bump Stop 1" Multimount Made by Prothane Motion Control. Just got them today. I haven't mounted them yet. But they are certainly bigger than what I now have on there.
Update: I went out to the shop and compared the new bump stops with the hole spacing of the original bump stops I took off a long time ago. The holes on the new bumps are about a 1/4" off. The holes on the new will need to be slightly lenghtened. Not a big deal but I wanted to mention it as they are NOT direct bolt on's. Good Luck...
Old Apr 16, 2010 | 10:40 PM
  #1135
OklaHemi's Avatar
OklaHemi
ground force
Old Apr 17, 2010 | 03:24 AM
  #1136
blackmamba13's Avatar
blackmamba13
Hey guys...didn't think to ask this earlier but just occured to me the other day. So as I have mentioned before I will be lowering the rear with the drop shackles and I've pretty much decided I would do the O/L delete to achieve that level I want. So what about the shocks do I need to change those or can I leave the bilsteins that I got on there? BTW this past week I put a new grill, headlights, and magnaflow dual exhaust on my ride! Had a flow master single on before. Big improvement to me.
Old Apr 17, 2010 | 08:57 AM
  #1137
OklaHemi's Avatar
OklaHemi
new shock will help ride quality at the least you should get shock extenders so you can run your stockers. if you are buying a kit the normally come with it.
Old Apr 17, 2010 | 01:12 PM
  #1138
blackmamba13
Extenders...wow that shows how little I know about this. For some reasonI was thinking that dropping the rear would compress not extend the shock, but after seeing how the shackle functions I get it now. Glad I asked. So the 2" Mcgaughys drop shacks that I got on order is going to come with the extenders? Didn't see them listed on the description for this.
Old Apr 17, 2010 | 01:27 PM
  #1139
SilverBullet08's Avatar
SilverBullet08
you can ride the stock shocks on just drop shackles...
Old Apr 17, 2010 | 02:40 PM
  #1140
blackmamba13
So no need for extenders right?
